Cell connection with or without Dialer-Interface?
i would like to set up a Cisco 2921 ISR G2 with an EHWIC-4G-LTE-G to connect to an UMTS/LTE network.
I found two different ways to configure the connection:
1) Directly under the Cell-Interface
interface Cellular0/1/0
 ip address negotiated
 ip nat outside
 ip virtual-reassembly in
 encapsulation slip
 dialer in-band
 dialer idle-timeout 0
 dialer string lte
 dialer-group 1
 async mode interactive
2) In conjunction with a Dialer-Interface:
 encapsulation slip
 dialer in-band
 dialer pool-member 1
 routing dynamic
interface Dialer1
 encapsulation slip
 dialer pool 1
 dialer string lte
 dialer persistent
 dialer-group 1
Could someone please explain which one would be the preferred method, or in other words: Does using a dialer - interface has any advantages
over the direct method?
Thanks!
Hello.
Per Cisco documentation, the prefered method is to use Dialer interface.
PS: not sure why; maybe they extend functionality of Cellular interface to run more than one Dialer on a single physical interface.
