we are looking for a replacement of our ASR1001-X.
if I got it right, the direct replacement is a C8500L-8S4X router. but not sure if CGN is supported there or not.
some presentations just shows that C8500-12X and C8500-12X4QC supports CGN, which are -HX replacement.
I expect all features, that are possible on 1001-x should also works on C8500L-8S4X
Thanks & Regards
Martin
