Challenge with my router 3825
dsrv22001
Hi everybody,
I am facing one challenge since this morning by installing HWIC-2CE1T1-PRI on my cisco router 3825. So after installation of  the card, i power on the router but in ''show diag'' the card is not appear, same thing even by trying to move it to another slot. After checking on internet this card is compatible with this kind of router. Any idea of what is happen? please i need help urgently.
thanks by advance
Mark Malone
Hi its hardware so theres not much you can do but take it out and re-insert it give it another reboot and hope it comes up
If its still not working try it in another platform if possible , the card could be d.o.a it does happen and Cisco will replace them if they come out like this , you will need to go through your re seller though
Although you say that the 3825 is compatable have you checked you have the min supported IOS
Platform Support
Refer to the software release notes or the Cisco IOS Software Upgrade Planner, or ask your local Cisco representative for information about supported platforms and minimum software and memory requirements. Table 2 shows the minimum Cisco IOS Software requirements for each platform.
Table 2. Minimum Cisco IOS Software Requirements
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/network-modules/product_data_sheet0900aecd80710c88.html
2800, and 3800 Series
2900, and 3925, 3945
Cisco 3925E, 3945E
Minimum IOS Release
12.4(20)T
15.0(1)M
15.1(1)T
Minimum IOS Technology Package
IP Base
IP Base
IP Base
RegardsAlex
Regards, Alex. Please rate useful posts.
saif musa
Level 4
Level 4
Could you run ( sh version ) command please and upload the result here
