Changing a route-map
N3t W0rK3r
Level 3
Level 3
I have route-map defined on my ASR 1002 12.2(33)XNE and applied to my gi0/0/1 interface.  I need to change the IP address defined on the "set ip next-hop ..." line.  My question is, when I make the change in just the route-map definition, does the change take effect immediately, or do I need to remove and re-apply the "ip policy route-map ..." statement on the interface?  If I do have to remove and re-apply, will this be service-affecting for all the traffic flowing through the interface?  I'm just not sure what to expect.
Thanks in advance.
John
Hello
this was discussed in the past for the 6500 platform, the same should apply to ASRs:
https://supportforums.cisco.com/thread/2004171
You don't need to remove and reapply.
Francesco
Hello
Francesco
Thanks Francesco.  I know that some things are different on ASRs than other platforms (learned the hard way) so I wasn;t sure if this was one of those things.
John
