changing ref bw under ospf
alalli
Level 2
Level 2
Hi All,
Does setting the reference bandwidth under ospf require ospf process to be reset?
I don't think it does and plan to run a quick test.... Just wondered if anyone knew as well?
thanks very much,
royalblues
Level 10
Level 10
I think it does.
But make sure you have this setting on all the routers running OSPF in your domain.
HTH, rate if it does
Narayan
