08-05-2010 03:09 AM - edited 03-04-2019 09:19 AM
Hi All
Just wondering if it is possibel to set the MTU value on a specific gig port on a Cisco 7609 and if so what command would I use please?
Best Regards,
Michael
Solved! Go to Solution.
08-05-2010 03:17 AM
To configure MTU :
7609(config)#int gigabitEthernet 1/1 7609(config-if)#mtu ? <1500-9216> MTU size in bytes 7609(config-if)#mtu 921
7609#show interfaces gigabitEthernet 1/1 GigabitEthernet1/1 is up, line protocol is up (connected) Hardware is C6k 1000Mb 802.3, address is 0007.0d0e.640a (bia 0007.0d0e.640a) MTU 9216 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255
For more information Visit : http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
Uttam
08-05-2010 03:17 AM
To configure MTU :
Uttam
08-05-2010 03:23 AM
Hi There
Cheers for the quick response. I had just found that
The only time up to now I changed the MTU value was on the WAN interface on a Cisco 877 router adn that was done with the "ip tcp adjust" command so I was checking under "ip" on the interface.
Once I just used Cisco help under the interface I spotted the "mtu" command, doh
Best Regards & Thanks again,
Michael
