Changing the VC idle timeout
denzilstephens
We have our own B-RAS that various makes of DSL router connect to.
If there is a brief failure of the B-RAS the virtual interfaces fail and reconnect.
We have noticed the Cisco routers take over 5 minutes to reconnect whereas other makes only take 60 seconds. I believe this is due to the VC idle disconnect time on the Cisco ATM interfaces:
router#show int atm0/1/0
  VC idle disconnect time: 300 second
When i try to change this under the PVC configuration i receive the following error:
router(config)#int atm0/0/0
router(config-if)#pvc 0/38
router(config-if-atm-vc)#idle-timeout 60
idle timeout is only for svc and autovc
My full DSL config is:
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp Virtual-Template1
interface Virtual-Template1
mtu 1486
ip address negotiated
ip virtual-reassembly in
ip tcp adjust-mss 1446
keepalive 1 2
ppp pap sent-username ####### password 7 #########
Has anyone else experienced this issue? How can i reduce the VC idle timer?
Many thanks,
Denzil
John Blakley
According to the following link, the VC timeout is set to 5 minutes. The absolute minimum is 0:
http://www.cisco.com/en/US/docs/ios/12_2/wan/command/reference/wrfatmtx.html#wp1018694
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi John,
Unfortunately i am uanble to use that command:
I am using PVCs and am not sure how to do otherwise or if there is another way to set the timeout.
Any ideas?
Denzil
