Channelized/PRI Card
vinay4301
Can we use NM-2CE1T1-PRI & HWIC-2CE1T1-PRI , both modules in 3845 Router simultaneously . Is there any limitation for using the same or any performance degradation
Leo Laohoo
Don't think the NM-2CE1 is compatible with the 3800 router.
WAN Interface Card (WIC) / Platform Hardware Compatibility Matrix for 1600, 1700, 2600, 3600 and 3700 Series Routers
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
Hi Vinay,
Both these modules are supported on 3845 router.
However NM-2CE1T1-PRI module has been announced EoS and the replacement is HWIC-2CE1T1-PRI -
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/eol_c51_484362.html
Any specific reasons why you are still looking for the NM.
-> Sushil
