check alarm on 7200 router
kunalgandhi
I have 7200 router.
Can any one tell me that how can I check the ds3 link alarms on 7200 router.
I have minimum access on router.
Waiting for reply....
Here is a good doc that explains the main errors/alarms you can take on a DS3:
http://www.cisco.com/en/US/tech/tk39/tk48/technologies_tech_note09186a0080111093.shtml
Its written for ATM DS3 controllers, but most of it holds true for standard serial DS3.
5 Replies 5
sivakondalarao
PLS TRY
sh controllers e1
wochanda
Level 4
Level 4
If it is a channelized DS3 card it will be
show controllers t3 slot/port
If it is clearchannel, it will be
show controllers serial slot/port
Thanks a lot...
I am able to check alarm on 7200 with command
sh controller serial slot/port.
10xs for reply
And its good if U can send me the types of alarms and there meanings.
Thanks for your reply.
