CHECK OUT THIS CONFIGURATION
tomocisco
We are presently using the config below to connect our Branch office1 LAN to the Head Office. We have Cisco2800 at Head office and Branch office1.
We want to connect the Branch office1 to another Branch office2.
the Cisco 2800 we are using has only 2 fast ethernet interfaces, so we decided to configure sub interfaces on one of the fast ethernet interface.
The Branch office2 will use Cisco871.
I attached here a simple network topology of our network and the configuration i made. (i tried this on my simulator, but i could not ping end to end.)
With the configurations below, will I be able to connect our Head office to the branch office2?
Is the configuration on Branch Office2 and 2950 switch ok.
Is my topology drawing ok, We use 2950 switch at branch office1.
Head Office
Router Configuration (Cisco2800)
conf t
int fa 0/1
description $WAN Interface$
ip address 172.30.1.1 255.255.255.0
int fa 0/0
description $LAN Interface$
ip address 172.20.1.1 255.255.255.0
exit
ip route 172.25.2.0 255.255.255.0 172.30.1.2 permanent
ip route 172.25.3.0 255.255.255.0 172.30.1.2 permanent
ip route 172.25.5.0 255.255.255.0 172.30.1.2 permanent
exit
Branch 1 Office router configuration (cisco2800)
conf t
int fa 0/1
ip address 172.30.1.2 255.255.255.0
no shut
int fa 0/0
description $native vlan$
ip address 172.25.2.1
int fa 0/0.10
encapsulation dot1q 10
description $VLAN TO Branch 2 $
ip address 172.25.3.1 255.255.255.0
exit
conf t
ip route 172.25.5.0 255.255.255.0 172.25.3.2 permanent
ip route 172.20.1.0 255.255.255.0 172.30.1.1 permanent
exit
Branch 1 office Switch (cisco2950) configuration
conf t
int vlan 1
ip address 172.25.2.2 255.255.255.0
exit
exit
vlan database
vlan 10
exit
int fa 0/1
switchport mode access
switchport access vlan 10
exit
int fa 0/12
switchport mode trunk
exit
Branch 2 office router configuration (cisco 871)
conf t
int vlan 1
ip address 172.25.5.1 255.255.255.0
exit
int fa 4
ip address 172.25.3.2 255.255.255.0
no shut
exit
ip route 172.25.2.0 255.255.255.0 172.25.3.1 permanent
ip route 172.30.1.0 255.255.255.0 172.25.3.1 permanent
ip route 172.20.1.0 255.255.255.0 172.25.3.1 permanent
exit
bwilmoth
Level 5
Level 5
In Branch 1 office router configure the subnet mask for the ip address “172.30.1.2”
For interVLAN routing, be sure to configure the default gateway on all workstations that connect to the switches. This default gateway is the IP address that you configure on the sub interface. You create a sub interface on the router for each VLAN.
The following URL helps to configure Intervlan routing between a router and switch:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a00800ef797.shtml#diag
bwilmoth
Level 5
Level 5
