Check QoS Settings - ME6524?
jrtuckiii
We are running IOS 12.2.33SXH on our 66524 and 6509 switches. What is the best way to check if packets are hitting the QoS queues properly? On a Juniper, all I have to do is run command - "show interfaces fe-0/0/1 statistics detail | find "Queue counters:"" and I can see packets hitting each of the queues. Is there a similar command I can run on the Cisco to see the same thing?
Thank you.
drolemc
Level 6
Level 6
Try these commands.
show queue int 4/0
show policy interface Serial 3/
shinepjoseph68
I am wondering if you can share the 6524/6509 QoS config??
Thanks in advance.
