Checking an over utilised serial sub interface
willemvwyk
Hello If I have sub interface s0/2.23 how can I see on the actual interface how much traffic is running over.
I asked this question relating to graphing the interface and got excellent response.
However, checking the interface itself without graphing it, how will I determine how much traffic is running over this interface
thank you
wvw
guruprasadr
Level 7
Level 7
HI, [Pls Rate if Helps]
You have to verify the below Information in the Show Output of Serial Interface.
INCHER01>show int se 0/2.23
Serial1/0 is up, line protocol is up
reliability 255/255, txload 43/255, rxload 57/255
5 minute input rate 10038000 bits/sec, 2227 packets/sec
5 minute output rate 7534000 bits/sec, 2095 packets/sec
722906785 packets input,
Received 76836 broadcasts,
INCHER01>show int serial 0/2.23 stats
========>This Command will give the Statistics of entire Serial Interface Traffic
PLS RATE if HELPS
Best Regards,
Guru Prasad R
To get a more accurate snap shot you can use the load-interval 30 command under the interface to drop the interval from 5 mins to 30 secs. This will help track the spikes in utilization a little better. The other nice thing about this command is it applies to show policy map interface outputs too.
In my opinion 30 secs isn't that create either so a lot of times I will use the SDM to look at utilization in 10 sec intervals if I think traffic is bursting up to the ceiling.
On a side note, I'm amazed at what the SDM can do, it 's almost good enough to but us engineers out of a job.
Hi I think I am running an older IOS as I don't have the command 😞
Mainrouter1#sh int s0/1.39 ?
description Show interface description
precedence Show interface precedence accounting info
rate-limit Show interface rate-limit info
| Output modifiers
