MPLS VPN question-lab environment
mrunal_47
I did it couple of times but it didnt work. I am just trying to build MPLS L3 VPN with OSPF as the PE-CE protocol, EIGRP running within the MPLS cloud and PE-PE protocol being MP-BGP. PE router perform mutual redistribution and the routing table at CE, C and PE routers are exactly the way they should be. PE routers have the right VRF table for that particular VPN. With all the routes in the routing table, I thought that a ping between C and C router should work. However they dont, and I am having some trouble to figure out the reason for this. MP-BGP also exists between PE routers and so does OSPF neighborship between PE and CE routers at both sides. Can anyone guide me the reason for failig pings?? I have tried enough .. :)
cisco_lad2004
Level 5
Level 5
It sounds like ur LSP path is broken.
do a sh ip cec vrf x.x.x.x and trace the tags hop by hop.
one of the classic reasons is that u might not be using Loopbacks as host addresses for BGP peering.
Sam
Yes, I did MP-BGP peering using IP address of serial interfaces on both routers. I did not do any loopback peering using update-source. Why would you think loopback interfaces is a must in this case? I will reconfigure the lab again and test it.
Thanks!
Alright, I configured loopbacks and did BGP peering between them and it works now. I just wanted to know why is this must to configure only through loopbacks?
U need to have NH from PE to PE as a Host address. and therefore P2P wont give u that, only LP can.
Sam
