Circuit Emulation Group (CEM) intermittantly dropping
mark.mcsherry
I've configured up a CEM card and have the circuit working. Roughly every 20 minutes it drops the circuit and restarts it. The ISDN underneath looks fine. Can anyone explain what the 'Egress pkts dropped by burst control' are. They're the only thing I can see that might be causing my issue.
thanks,
Mark
cem info
cem 1/0/1 is down
Line state is down
Operational state is config-incomplete
Near end ip address: 10.40.6.74, udp port: 15900
Far end ip address: 10.40.6.73, udp port: 15900
IP payload size: 336
IP dscp : 0x2E
Idle pattern length: 8 , Idle Pattern: 0xFF
Payload compression is enabled
Data protection is disabled
Dejitter buffer size is 36 ms
Channel clock rate is 896000 bps
CEIP header CRC is disabled
Signaling is disabled
Physical interface is E1 channelized
Ingress packets: 246628, dropped: 0, overruns: 0, max_ipt: 7
Egress packets: 246417, dropped: 0, lost pkts: 0
Egress out of sequence pkts: 0
Egress overruns: 0, underruns: 57, ur_delay: 0, ur2pkt: 25
Egress pkts dropped by burst control: 827
Egress corrupt pkts rcvd: 0
30 second ingress rate 0 bits/sec, 0 packets/sec
cem info
30 second egress rate 0 bits/sec, 0 packets/sec
Tx interrupts: 245593
Reorder queue flush: 0, visited: 0, max wait window: 0
Pkt-to-pkt jitter max: 10 ms, average: 2 ms, min: 0 ms
Dejitter buffer level max: 28 ms, min: 3 ms
Event history: 0x00730050
Effective compression: 85%
Compressed pkts: 246628
Pkts dropped by PCI burst limit: 0
Global stats for slot 1
Clk derived from : Backplane
Egr free buf: 256
Egr host overruns: 0
Egr unknown dest count: 2189
Last unknown dest ip : 10.40.6.74, port: 15900
Last unknown dest src ip : 10.40.6.73, port: 15900
Egr process switched: 0
Egr oos: 0
Egr unknown src count: 0, last unknown src ip: 0.0.0.0, port: 0
Ingr overruns: 0
NM cpu: 48.42 48.42 48.42 48.42
cem info
umedryk
Level 5
Level 5
Note that the operational state is config-incomplete.In that Make sure an xconnect is defined.Command reference for xconnect is xconnect remote-ip-address virtual-connect-ID encapsulation encapsulation-type .Refer the following URL for more info
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008045523e.html#wp1132585
Thanks for the reply. I took the output while the xconnect was down, which is why it states that. The config was all ok, as it came up fine once a connection was brought up on the E1.
Once up though it was bouncing roughly every 15 to 20 minutes for around a second or so. I just wondered if there was some tuning of some sort I need to do..
thanks,
Mark
