Cisco 1100 behind existing router
alexander2003
I currently have a problem configuring it Cisco 1100 behind an existing modem.
The IP of the existing modem is 192.168.0.1
I have connected the Cisco 1100 via LAN the modem. The interface has the IP 192.168.0.99.
I have also set up the IP route, however I am not able to ping other devices.
Can anyone help me or tell me where the error is? Do I need NAT? Unfortunately I cannot set the existing router to bridge mode.
My goal would have been to connect the Cisco 1100 to the existing modem via the Gig0/0/0 interface. The LAN ports Gig0/1/0-7 should all be in VLAN 1 with the network 10.10.1.0.
I am 18 years old and new to the Cisco world. Would be very grateful for any help.
Config:
version 16.6
service password-encryption
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname CiscoRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$OBcO$UZPJhYt7xrDQwWIE4Y6l.1
no aaa new-model
ip dhcp pool lan-pool1
 network 10.10.1.0 255.255.255.0
 default-router 10.10.1.1
 dns-server 8.8.8.8
subscriber templating
crypto pki trustpoint TP-self-signed-3433423209
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3433423209
 revocation-check none
 rsakeypair TP-self-signed-3433423209
crypto pki certificate chain TP-self-signed-3433423209
license udi pid C1111-8P sn FCZ2240122N
diagnostic bootup level minimal
redundancy
 mode none
vlan internal allocation policy ascending
interface Loopback0
 no ip address
interface GigabitEthernet0/0/0
 ip address 192.168.0.99 255.255.255.0
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
interface GigabitEthernet0/1/0
 switchport mode access
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
 ip address 10.10.1.1 255.255.255.0
ip forward-protocol nd
no ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
control-plane
line con 0
 transport input none
 stopbits 1
line vty 0 4
 login
you are missing this line:
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
12 Replies 12
Two options here:
1) If your Modem/Router supports it, configure it with a static route for 10.10.1.0/24 with a next hop of 192.168.0.99.
2) If it doesn't support static routes, you need to configure NAT/PAT on your router.
The whole problem is that the Modem/router has no idea how to reach the network 10.10.1.0/24.
And you also should remove the route
This one is not needed here.
Richard Burts
There are some things in your post that are not clear. In some parts you refer the 1100 to be connected to a modem and in other parts you describe it connected to a router. Which is it?
Are you sure that 192.168.0.1 is the correct address of the device that you are connecting to? Can the 1100 ping that address? Perhaps the output of these commands on the 1100 might be helpful
show ip interface brief
show ip route
show arp
You say that you are not able to ping other devices. What devices are these? What are their IP addresses? Are they reached through interface G0/0/0 (on the outside) or are they reached through interface vlan 1?
I have some comments about your configuration.
- You have configured 2 static default routes
It appears that both of them describe the same forwarding path. You only need one of them. For several reasons I would suggest that you remove the entry that specifies the outbound interface and keep the entry that specifies a next hop address.
- It is not clear whether this modem/router that you connect to is connected to the Internet (seems likely) or is connected to something else (in which case please clarify what it connects to).
# if connected to the Internet then there needs to be Network Address Translation to allow your inside network 10.10.1.0 to access the Internet. Perhaps the modem/router might be able to do that NAT? Or else you will need to configure NAT on your 1100.
# if connected to something else then whatever it is connected to will need routing information about both 10.10.1.0 and perhaps 192.168.0.0
Rick
Thank you for the quick reply.
The Cisco 1100 is connected to a router, which is also responsible for Internet access, so it is directly connected to the Internet. The IP address of the router is 192.168.0.1.
The IP address can also be pinged from the 1100. However, it is not possible to ping another computer on the 192.168.0 network.
How do I set up NAT on the 1100? Internface gig0/0/0 is my ip nat outside. But what is my IP nat inside? In that case all my ports (0/1/0-7) would be my ip nat inside?
make the changes marked in bold:
version 16.6
boot-start-marker
boot-end-marker
no aaa new-model
--> ip dhcp excluded-address 10.10.1.1
dns-server 8.8.8.8
redundancy
mode none
interface Loopback0
no ip address
--> ip nat outside
negotiation auto
no ip address
negotiation auto
interface Vlan1
--> ip nat inside
no ip http server
--> ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
--> no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
--> access-list 1 permit 10.10.1.0 0.0.0.255
control-plane
line con 0
stopbits 1
line vty 0 4
login
end
Thanks for the answer.
I have made the changes.
Now I can send a ping directly from the router to google.com, etc..
But now when I connect my PC it gets the IP address 10.10.1.2 but I can't ping to 192.168.0.1 or open a page.
can your PC ping 192.168.0.99 ?
Yes, I can ping 192.168.0.99 from the PC.
post the running configuration again with the changes you have made.
Attached is the current config.
Thanks a lot!
version 16.6
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
redundancy
mode none
interface Loopback0
no ip address
ip nat outside
negotiation auto
no ip address
negotiation auto
interface Vlan1
ip nat inside
no ip http server
control-plane
line con 0
stopbits 1
line vty 0 4
login
end
Now it works!
Thanks a lot!
