Cisco 1100 ISP Failover
InSysProllc
Dear Forum,
I'm reaching out for an issue I'm having with a Cisco 1100 running IOS 9.17.09.05. The router is connected to 2 WAN ports with a simple failover config. The primary WAN is on G0/0/0 and the backup is on G0/0/1. When ISP1 (ATT) drops, the default route is changing to ISP 2 (Comcast) but it will not route past the gateway. Nat tables don't show any entries on the tables when it cuts over.
Troubleshooting steps I've tried:
1. Verified static IP information and route on the ISP 2.
2. Tried forcing a network out directly to ISP 2 with policy mapping on a single VLAN.
3. Tried adding track 10 and track 10 with SLA's on both interfaces.
4. Tried standard ACL's to see if there is anything blocking the outbound.
I have a single site to site VPN that's not applied right now but it's only on the primary interface.  For the config I have:
boot system bootflash:c1100-universalk9.17.09.05a.SPA.bin
ip name-server 1.1.1.1 8.8.8.8 10.17.1.200
track 10 ip sla 10 reachability
crypto isakmp policy 1
 encryption 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key XXXXXXX address XXX.XXX.XXX
crypto isakmp keepalive 60 30
crypto ipsec transform-set SRAWH esp-3des esp-md5-hmac
 mode tunnel
crypto ipsec profile XXX
 set transform-set XXX
crypto map XXX 10 ipsec-isakmp
 set peer X.X.X.X
 match address XXXX
interface Tunnel0
 ip address 10.19.1.250 255.255.255.240
 tunnel source X.X.X.X
 tunnel destination X.X.X.X
 tunnel protection ipsec profile XXXX
interface GigabitEthernet0/0/0
 description ATT
 ip address X.X.X.X 255.255.255.248
 ip nat outside
 negotiation auto
interface GigabitEthernet0/0/1
 description COMCAST
 ip nat outside
 negotiation auto
interface GigabitEthernet0/1/0
 description Link to LAN
 switchport mode trunk
interface GigabitEthernet0/1/1
 description Link to PBX
 switchport access vlan 30
 switchport mode access
interface GigabitEthernet0/1/2
 switchport access vlan 10
interface GigabitEthernet0/1/3
 description Monitoring System
interface Vlan1
 ip address 10.1.1.250 255.255.255.0
 ip nat inside
interface Vlan10
 ip address 10.17.1.206 255.255.255.240
 ip nat inside
interface Vlan11
 description MGMT
 ip address 10.17.1.14 255.255.255.240
 ip helper-address 10.17.1.200
 ip nat inside
interface Vlan12
 description REGULATORY
 ip address 10.17.1.30 255.255.255.240
 ip nat inside
interface Vlan14
 description BUSDEV
 ip address 10.17.1.46 255.255.255.240
 ip nat inside
interface Vlan15
 description ACCOUNTING
 ip address 10.17.1.62 255.255.255.240
 ip nat inside
interface Vlan20
 description CLINOPS
 ip address 10.17.2.250 255.255.255.0
 ip nat inside
interface Vlan30
 description VOICE
 ip address 10.17.3.250 255.255.255.0
 ip nat inside
interface Vlan40
 description CAMERAS
 ip address 10.17.4.250 255.255.255.0
 ip nat inside
interface Vlan50
 description GUEST
 ip address 10.17.5.250 255.255.255.0
 ip nat inside
interface Vlan60
 description ACCESSCNTRL
 ip address 10.17.6.250 255.255.255.0
 ip nat inside
interface Vlan70
 description DATALOGGER
 ip address 10.17.7.250 255.255.255.0
 ip nat inside
ip local policy route-map IPSLA10
no ip http server
ip http authentication local
no ip http secure-server
ip forward-protocol nd
ip nat settings interface-overload block port tcp 5150
ip nat settings interface-overload block port tcp 5160
ip nat inside source static tcp 10.17.4.200 5150 X.X.X.X 5150 extendable
ip nat inside source static tcp 10.17.4.200 5160  X.X.X.X 5160 extendable
ip nat inside source list 101 interface GigabitEthernet0/0/0 overload
ip nat inside source list 102 interface GigabitEthernet0/0/1 overload
ip route 0.0.0.0 0.0.0.0 X.X.X.X track 10 (ATT)
ip route 0.0.0.0 0.0.0.0 X.X.X.X 2 (Comcast)
ip route 10.12.1.0 255.255.255.0 Tunnel0
ip route 10.12.2.0 255.255.255.0 Tunnel0
ip route 10.12.3.0 255.255.255.0 Tunnel0
ip access-list extended IPSLA10
 10 permit icmp X.X.X.X (ATT) 0.0.0.7 8.8.8.8 0.0.0.3
ip access-list extended SRAWHVPN
 10 permit ip 10.17.1.0 0.0.0.255 10.12.1.0 0.0.0.255
 20 permit ip 10.17.2.0 0.0.0.255 10.12.2.0 0.0.0.255
 30 permit ip 10.17.3.0 0.0.0.255 10.12.3.0 0.0.0.255
ip sla 10
 icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0/0
  timeout 6000
  frequency 10
ip sla schedule 10 life forever start-time now
ip access-list extended 101
 10 deny ip 10.1.1.0 0.0.0.255 10.12.1.0 0.0.0.255
 20 deny ip 10.17.1.0 0.0.0.255 10.12.1.0 0.0.0.255
 30 deny ip 10.17.2.0 0.0.0.255 10.12.2.0 0.0.0.255
 40 deny ip 10.17.3.0 0.0.0.255 10.12.3.0 0.0.0.255
 50 deny ip 10.17.4.0 0.0.0.255 10.12.4.0 0.0.0.255
 60 deny ip 10.17.5.0 0.0.0.255 10.12.5.0 0.0.0.255
 70 deny ip 10.17.6.0 0.0.0.255 10.12.2.0 0.0.0.255
 80 deny ip 10.17.7.0 0.0.0.255 10.12.2.0 0.0.0.255
 90 permit ip 10.1.1.0 0.0.0.255 any
 100 permit ip 10.17.1.0 0.0.0.255 any
 110 permit ip 10.17.2.0 0.0.0.255 any
 120 permit ip 10.17.3.0 0.0.0.255 any
 130 permit ip 10.17.4.0 0.0.0.255 any
 140 permit ip 10.17.5.0 0.0.0.255 any
 150 permit ip 10.17.6.0 0.0.0.255 any
 160 permit ip 10.17.7.0 0.0.0.255 any
ip access-list extended 102
 1 deny ip 10.1.1.0 0.0.0.255 10.12.1.0 0.0.0.255
 2 deny ip 10.17.1.0 0.0.0.255 10.12.1.0 0.0.0.255
 3 deny ip 10.17.2.0 0.0.0.255 10.12.2.0 0.0.0.255
 4 deny ip 10.17.3.0 0.0.0.255 10.12.3.0 0.0.0.255
 5 deny ip 10.17.4.0 0.0.0.255 10.12.4.0 0.0.0.255
 10 deny ip 10.17.5.0 0.0.0.255 10.12.5.0 0.0.0.255
 20 deny ip 10.17.6.0 0.0.0.255 10.12.6.0 0.0.0.255
 30 deny ip 10.17.7.0 0.0.0.255 10.12.7.0 0.0.0.255
 40 permit ip 10.1.1.0 0.0.0.255 any
 50 permit ip 10.17.1.0 0.0.0.255 any
 60 permit ip 10.17.2.0 0.0.0.255 any
 70 permit ip 10.17.3.0 0.0.0.255 any
 80 permit ip 10.17.4.0 0.0.0.255 any
 90 permit ip 10.17.5.0 0.0.0.255 any
 100 permit ip 10.17.6.0 0.0.0.255 any
 110 permit ip 10.17.7.0 0.0.0.255 any
route-map IPSLA10 permit 10
 match ip address IPSLA10
 set ip next-hop X.X.X.X (ATT GW)
sho ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, m - OMP
       n - NAT, Ni - NAT inside, No - NAT outside, Nd - NAT DIA
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       H - NHRP, G - NHRP registered, g - NHRP registration summary
       o - ODR, P - periodic downloaded static route, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
       & - replicated local route overrides by connected
Gateway of last resort is X.X.X.X (ATT) to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via X.X.X.X (ATT)
      10.0.0.0/8 is variably subnetted, 24 subnets, 3 masks
C        10.1.1.0/24 is directly connected, Vlan1
L        10.1.1.250/32 is directly connected, Vlan1
C        10.17.1.0/28 is directly connected, Vlan11
L        10.17.1.14/32 is directly connected, Vlan11
C        10.17.1.16/28 is directly connected, Vlan12
L        10.17.1.30/32 is directly connected, Vlan12
C        10.17.1.32/28 is directly connected, Vlan14
L        10.17.1.46/32 is directly connected, Vlan14
C        10.17.1.48/28 is directly connected, Vlan15
L        10.17.1.62/32 is directly connected, Vlan15
C        10.17.1.192/28 is directly connected, Vlan10
L        10.17.1.206/32 is directly connected, Vlan10
C        10.17.2.0/24 is directly connected, Vlan20
L        10.17.2.250/32 is directly connected, Vlan20
C        10.17.3.0/24 is directly connected, Vlan30
L        10.17.3.250/32 is directly connected, Vlan30
C        10.17.4.0/24 is directly connected, Vlan40
L        10.17.4.250/32 is directly connected, Vlan40
C        10.17.5.0/24 is directly connected, Vlan50
L        10.17.5.250/32 is directly connected, Vlan50
C        10.17.6.0/24 is directly connected, Vlan60
L        10.17.6.250/32 is directly connected, Vlan60
C        10.17.7.0/24 is directly connected, Vlan70
L        10.17.7.250/32 is directly connected, Vlan70
      50.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        X.X.X.X (Comcast)/29 is directly connected, GigabitEthernet0/0/1
L        X.X.X.X (Comcast)/32 is directly connected, GigabitEthernet0/0/1
      107.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        X.X.X.X (ATT)/29 is directly connected, GigabitEthernet0/0/0
L        X.X.X.X (ATT)/32 is directly connected, GigabitEthernet0/0/0
Any suggestions would be greatly appreciated. I've been battling with this for a week now. I've even tried the solution in another thread:
https://community.cisco.com/t5/routing/cisco-1100-router-dual-wan-configuration/td-p/4754796
But it doesn't seem to properly fail over.
Thank you everyone for an suggestions
Giuseppe Larosa
Hello @InSysProllc ,
when dealing with NAT over multiple WAN L3 uplinks the NAT configuration needs to use route-maps in NAT statement like
route-map ISP_1 permit 10
match ip address 101
match interface GigabitEthernet0/0/0
route-map ISP_2 permit 10
match interface GigabitEthernet0/0/1
please notice that the match interface in this case matches the outgoing interface and this is the key to make NAT to work.
In this way when you are using the first WAN interface only the first route-map matches. If using the second WAN the second route-map matches making NAT to work without ambiguity.
ip nat inside source route-map ISP_1 interface GigabitEthernet0/0/0 overload
ip nat inside source route-map ISP_2 interface GigabitEthernet0/0/1 overload
I have taken this example from the thread you have linked
You should change your NAT config to use something like the above example.
Hope to help
Giuseppe
Giuseppe Larosa
Hope to help
Giuseppe
Hello Giuseppe,
Thank you very much for suggestion. I have some downtime on the site tomorrow so I can test and provide feedback.
Thanks!!
InSysProllc
That solution worked! Thank you for the suggestion!
I've posted the updated brief config for anyone who may encounter the same issue:
ip nat inside source list route-map ISP_2 interface GigabitEthernet0/0/1 overload
ip route 0.0.0.0 0.0.0.0 X.X.X.X track 10 (ISP_1)
ip route 0.0.0.0 0.0.0.0 X.X.X.X 2 (ISP_2)
 10 permit icmp X.X.X.X (ISP_1) 0.0.0.7 8.8.8.8 0.0.0.3
ip sla 10
  timeout 6000
  frequency 10
ip access-list extended 101 (Example)
 set ip next-hop X.X.X.X (Primary GW)
The only other note was adding an ACL to send the icmp through the primary gateway only to prevent mismatches on the ISP side.
Thank you Giuseppe for the assistance!
