learning same route in all VRF
knaik99
 on Data center router ,we have 6 VRF and let say we have subnet 10.x.x.x/18  and this subnet route is seen in all 6 vrf on that Data center router
is it possible ?
as i learnt that VRF creates separate routing table then how can we see one subnet route in all VRF
Joseph W. Doherty
Yes, it's possible via "routing leaking".
routing leaking can be done via route target and any other way than this
Another way?
Well, if the route, somehow, was physically advertised into each VRF.
elwin-berrar
Yes exactly, that’s how VRF keeps routes separated. The leaking part just lets you share specific routes when needed between VRFs.
https://pingmynetwork.com/network/ccna-200-301/virtual-routing-and-forwarding https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/216541-vrf-configuration-examples-on-ios-xe.html
