Cisco 1721 Mulitple T1
DOUGLAS EVANS
Sorry, I know that 1721 is EOL,  but client wants to use existing 1721 DIA Router using three(3) T1s. Will the 1721 support 3 T1s and Are the
VWIC2-1MFT-T1/E1 & VWIC2-2MFT-T1/E1 interfaces supported or is there a better inferface available.  I remember awhile back that V2 WIC cards were an issue on the 1721.  I'm sure the IOS version will also be a consideration.
Thank you
DJE
Hi DJE,
The 1721 has two WAN interface card (WIC) slots  and you can use VWIC-2MFT-T1 or VWIC-1MFT-T1 depending on your requirement. However this router you canno have V2 cards.
Please see the  below link for more infomration on this.
This document explains about the supported WAN cards and other features of 1721.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00800920ec.html
I also want to share with you another URL where you will get a details about relevent module and supported platforms. Please see the same below.
http://www.cisco.com/en/US/products/ps10537/products_relevant_interfaces_and_modules.html#brimod
Hope this will help
Muhammed M
Hi DJE,
Hope this will help
Muhammed M
