CISCO 1750 Serial interface line protocol not coming UP
rajeshcrraj
After upgrading bandwidth from 128 Kbps to 256 Kbps, serial interface showing "Serial0 is up, line protocol is down" , is there any chance of issue with Framing config mismach or what all possibilities can be.
Kindly help me out to resolve the same issue....
Rajesh Raghavan
Mahesh Gohil
Level 7
Level 7
Hi rajesh,
Yes there is chance of framing mismatch if  younare using framed circuit.
please verify both end for same no. of timeslots
regards
Mahesh
mavespig
Level 3
Level 3
Hi Rajesh,
I assume your topology is something like this:
router ---- Telco CSU/DSU ----- Telco network/Internet
If the Telco increased just the bandwidth, I would expect that they didn't change the framing...
What is your original configuration and what did you change after the upgrade?
Marco
