Cisco 1801 WAN DSL basic setup with FTTP (Aus)
magginoodles
Hi Everyone, I'm a complete noob who wants to use my Cisco 1801 to connect my WAN interface to the NBN NTD (using dynamic IP) to handle my home network.
A network engineer in my last company helped me and it worked perfectly for DSL. Now I have FTTP and I'm stuck :(  Any help would be appreciated.
This is what I"m trying to do
fe 0 - WAN (DHCP by ISP) vlan ?? does this need its own vlan, I'm reading up on ipnat inside/outside
fe 1 - LAN (static IP) 10.0.0.1 vlan 99 now
fe 2 - LAN (connected to TPLINK gigabit switch with 16 ports) can this be DHCP from the router?
Yes I could use a cheap router but my Cisco has been so reliable I don't want to throw it away... if its not going to work I guess I could buy some simple router
I have set up a basic interface, and fiddled with it a bit.  The 1801 only has 1 WAN interface, I've made the assumption this the right interface as with it locally through serial I can ping web sites etc using it locally on the CLI
If I can provide any more info, outputs happy to run those commands
Using 1493 out of 196600 bytes
! Last configuration change at 01:29:28 UTC Sun Oct 14 2018
version 15.0
no service dhcp
hostname magginoodles
boot-start-marker
boot-end-marker
enable secret 5 $1$Zb/.$0Hkr1XdjmX4Wccx7r57vo/
enable password XXXXXXXX
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip name-server 203.215.29.191
ip name-server 203.0.178.191
no ipv6 cef
license udi pid CISCO1801/K9 sn FHK112719GH
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn point-to-point-setup
interface FastEthernet0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet1
 switchport access vlan 99
interface FastEthernet2
 shutdown
interface FastEthernet3
 shutdown
interface FastEthernet4
 shutdown
interface FastEthernet5
 shutdown
interface FastEthernet6
 shutdown
interface FastEthernet7
 shutdown
interface FastEthernet8
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan99
 ip address 10.0.0.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
 password XXXXXXXXXX
 login
end
keep in mind that your 1801 is not directly connected to the Internet, but to your modem, which also translates (NAT) everything.
I have made a few adjustments to your config (marked in bold):
! Last configuration change at 03:50:33 UTC Sun Oct 14 2018
version 15.0
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp pool VLAN99
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 8.8.8.8 8.8.4.4
lease 7
ip cef
no ipv6 cef
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
spanning-tree portfast
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan99
ip address 192.168.0.1 255.255.255.0
ip nat inside
no ip http server
ip nat inside source route-map NAT interface FastEthernet0 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0 dhcp
access-list 1 permit 192.168.0.0 0.0.0.255
route-map NAT permit 10
match ip address 1
match interface FastEthernet0
control-plane
line con 0
line aux 0
line vty 0 4
password XXXXX
login
end
Francesco Molino
Can you run the command:
sh ip int brie | ex unas
The configuration for Fa0 looks like ok and you should be able to get an IP from your ISP.
However, on the WAN side, you're missing the default route. You'll need:
ip route 0.0.0.0 0.0.0.0 dhcp
For LAN side:
If you want to connect a dumb switch (not manageable and not able to do trunking), you'll need to configure your Fa2 like Fa1. Am i correct if I understood that Fa2 and Fa1 will be on same LAN except Fa2 has switch whereas Fa1 has a endpoint?
To allow your router acting as dhcp server for this vlan 99, here a config example:
ip dhcp exclude-address 10.0.0.1
ip dhcp pool VLAN99
 network 10.0.0.0 255.255.255.0
 default-router 10.0.0.1
Also, you need to enable nat for this vlan:
interface vlan 99
 ip nat inside
ip access-list extended NAT
 permit ip 10.0.0.0 0.0.0.255 any
ip nat inside source list NAT interface fa0 overload
This is a simple configuration. If you'll have VPN for example, you'll need to deny nat for this remote subnet.
Then from the router, you should be able to ping 8.8.8.8 and from a machine, you should be able to get an ip and access Internet.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Thank you @Francesco Molino!
Here is the output from your command
magginoodles#sh ip int brie | ex unas
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              192.168.1.19    YES DHCP   up                    up
Vlan99                     192.168.0.1     YES manual up                    up
Pls note I moved to 192.168.0.0 as I didn't need so many addresses... don't know if that was the right thing to do or not :S
It's also connected to an Airport Extreme at the moment to just see if DHCP assigning was working, I had not even enabled DHCP yet... I'm such a goose
Here is the running config from your comments... I hope I got some of it right. I know the basic concepts of networking but I'm hardly a tech
magginoodles#show running-config
Building configuration...
Current configuration : 1827 bytes
version 15.0
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool VLAN99
   lease 7
ip cef
no ipv6 cef
interface ATM0
 no ip address
 shutdown
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan99
 ip nat inside
no ip http server
ip nat inside source list NAT interface FastEthernet0 overload
 permit ip 192.168.0.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
 password XXXXX
 login
end
Yes I'd like Fast Ethernet 1 to connect to my pc for a static IP
Fast Ethernet 2 would be connected to dumb switch as you say... a tplink switch I can add that in to make more sense of the config for you
I hope that makes sense, really appreciate the responses. Thanks
version 15.0
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool VLAN99
lease 7
ip cef
no ipv6 cef
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan99
ip nat inside
no ip http server
match ip address 1
control-plane
line con 0
line aux 0
line vty 0 4
password XXXXX
login
end
Thanks @Georg Pauwen, tweaked and up and running!
Current configuration : 2043 bytes
! Last configuration change at 11:42:23 UTC Sun Oct 14 2018 by amadge
version 15.0
boot-start-marker
boot-end-marker
enable password xxxxx
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool VLAN99
   lease 7
ip cef
ip domain name sodor
no ipv6 cef
username amadge privilege 15 secret 5 $1$G5DV$iD/8Q0n1v68VF/.BX8gpv.
interface ATM0
 no ip address
 shutdown
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan99
 ip nat inside
no ip http server
 match ip address 1
control-plane
line con 0
line aux 0
line vty 0 4
 password xxxxx
 login local
 transport input ssh
end
I just need to enable some access to internal devices from outside via the internet to my ubuntu home server on 192.168.0.10, SSH (port 22)
What is the easiest way? I found a few articles on permit I'm reading through now
How do I mark this done, fixed etc by people?
Many thanks,
Andrew
