Cisco 1811 as PPPoE-client, connection isn't established...
Anton Pestov
PPPoE connection isn't established...
Config Cisco 1811 (c181x-advipservicesk9-mz.124-15.T15.bin):
vpdn enable
vpdn-group 1
request-dialin
  protocol pppoe
bba-group pppoe global
interface Tunnel253
  tunnel source Dialer1
interface FastEthernet0
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname eprndu305_ll01
ppp chap password 7 PASSWORD
ppp pap sent-username USERNAME password 7 PASSWORD
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
_______________________________________________________
ROST-CE1#sh debugging
PPPoE:
  PPPoE protocol events debugging is on
  PPPoE control packets debugging is on
PPP:
  PPP authentication debugging is on
  PPP protocol negotiation debugging is on
ROST-CE1#
*Jul  5 17:24:35.915 MSK:  padi timer expired
*Jul  5 17:24:35.915 MSK:  Sending PADI: Interface = FastEthernet0
*Jul  5 17:24:35.915 MSK: pppoe_send_padi:
         FF FF FF FF FF FF 00 1B D5 AD A1 9C 88 63 11 09
         00 00 00 0C 01 01 00 00 01 03 00 04 84 CC BE 20 ...
*Jul  5 17:24:36.247 MSK: PPPoE 0: I PADI  R:c89c.1d23.9302 L:ffff.ffff.ffff Fa0
         FF FF FF FF FF FF C8 9C 1D 23 93 02 88 63 11 09
         00 00 00 9E 01 01 00 00 01 03 00 04 85 1B BE ...
*Jul  5 17:24:36.247 MSK:  Service tag: NULL Tag
*Jul  5 17:24:36.247 MSK: PPPoE 0: O PADO, R:001b.d5ad.a19c L:c89c.1d23.9302 Fa0
ROST-CE1#
         C8 9C 1D 23 93 02 00 1B D5 AD A1 9C 88 63 11 07
         00 00 00 BE 01 01 00 00 01 03 00 04 85 1B BE ...
ROST-CE1#
*Jul  5 17:24:39.259 MSK: PPPoE 0: I PADI  R:001d.0fc6.3876 L:ffff.ffff.ffff Fa0
         FF FF FF FF FF FF 00 1D 0F C6 38 76 88 63 11 09
         00 00 00 9D 01 03 00 04 10 04 61 00 01 01 00 ...
*Jul  5 17:24:39.259 MSK:  Service tag: NULL Tag
*Jul  5 17:24:39.259 MSK: PPPoE 0: O PADO, R:001b.d5ad.a19c L:001d.0fc6.3876 Fa0
         00 1D 0F C6 38 76 00 1B D5 AD A1 9C 88 63 11 07
         00 00 00 BD 01 03 00 04 10 04 61 00 01 01 00 ...
ROST-CE1#
*Jul  5 17:24:44.356 MSK: PPPoE 0: I PADI  R:001d.0fc6.3876 L:ffff.ffff.ffff Fa0
*Jul  5 17:24:44.356 MSK:  Service tag: NULL Tag
*Jul  5 17:24:44.356 MSK: PPPoE 0: O PADO, R:001b.d5ad.a19c L:001d.0fc6.3876 Fa0
ROST-CE1#sh pppoe session
     1 client session
Uniq ID  PPPoE  RemMAC          Port                    VT  VA         State
           SID  LocMAC                                      VA-st
    N/A      0  0000.0000.0000  Fa0                    Di1  N/A        PADISNT
                0000.0000.0000
HI Anton,
Thanks for writing your problem and resolution....it will help other guys ...if they face the same problem.
Can you please mark this question as answer so may be other can use this thread while getiing same problem.
Please rate if it helps.
8 Replies 8
adnane dakna
are you checking that remote site is well configured to work as pppoe server ?
Sandeep Choudhary
Try with this:
vpdn enable
vpdn-group 1
request-dialin
  protocol pppoe
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface Dialer1
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ip forward-protocol nd
please rate if it helps
I try this, but not work
are you using DSL connection ?
Optical fiber...
...when the very first time was connected everything worked with such configuration, and in half-day at night the channel was disconnected. From what it can occur?
Still relevant even today.
Your configs worked like a charm. Thanks.
Anton Pestov
Thanks to all for the help! ISP, at last, recognized an error on the side. On their side the binding to other MAC, distinct from from what PPPoE is initiated was registered.
HI Anton,
