Cisco 1811 Config issues
Chris Barron
For some reason I can not get the config correct on my 1811.
I have been banging my head against this for a week now.
I have a dhcp server at the ip listed as the helper address but for some reason I cant get a dhcp address on FE1 and cant get dhcp assigments on FE0 with any device I have plugged in.
What am I missing? Probably something so obvious its not funny, but I could use some help.
Thanks in advance
Below is my conf
Building configuration...
Current configuration : 1483 bytes
version 12.4
hostname router1.*********************
boot-start-marker
boot-end-marker
no logging console
enable secret 5 *******************************
enable password **********
no aaa new-model
dot11 syslog
no ip routing
no ip cef
archive
 log config
  hidekeys
interface FastEthernet0
 description LAN Interface
 ip address 10.10.2.42 255.255.0.0
 ip helper-address 10.10.2.99
 ip nat inside
 ip virtual-reassembly
 no ip route-cache
 duplex auto
 speed auto
interface FastEthernet1
 ip address dhcp
 ip nat outside
 no ip route-cache
 duplex auto
 speed auto
interface FastEthernet2
 shutdown
interface FastEthernet3
 shutdown
interface FastEthernet4
 shutdown
interface FastEthernet5
 shutdown
interface FastEthernet6
 shutdown
interface FastEthernet7
 shutdown
interface FastEthernet8
 shutdown
interface FastEthernet9
 shutdown
interface Vlan1
 no ip address
 no ip route-cache
interface Async1
 no ip address
 encapsulation slip
 no ip route-cache
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet1 overload
access-list 1 permit any
snmp-server community public RO
control-plane
line con 0
line 1
line aux 0
line vty 0 4
 password *****************
 login
end
router1.*****************#
6 Replies 6
On what interface is the DHCP server located? Because if it is is located on the F0 interface, you don't even need the "ip-helper" command. If your hosts and the server is located on the same LAN segment, they should find each other and the sever should be able to allocate an IP adress to the host.
The problem that F1 is not allocated an IP adress is harder to know.
The other part of this issue is that when I do get an ip on FE1 when its hooked to the modem
I can not get to the web from anything on FE0.
Any Ideas?
Your question reads as if you're trying to assign the address for FE1 via the DHCP server connected to FE0, that won't work for a couple reasons.  The router will send its DHCP request for FE1 out the FE1 interface, and the router won't assign the same subnet on two different routed interfaces.
Yet you said FE1 does get an IP from the modem's DHCP server as exected, and you have that as the nat outside interface... so I'm not entirely sure what the symtomps are sorry.
Sorry for the confusion, what is happening is that when I get an IP from the modem I can not reach the "outside". In other words, FE1 and FE0 are not "talking" to each other.
Hope this helps a little bit.
Please try by addig ip default route. i.e. ip route command.
pankajbhosale
Try this
no access-list 1 permit any
access-list 1 permit ip 10.10.0.0 0.0.255.255 any
Bye
