04-23-2017 06:04 PM - edited 03-05-2019 08:24 AM
Ok so my setup is, I have 2 vlans currently routing through fa0 on cable internet with DHCP. I want to be able to plug dsl, also dhcp, into fa1 and have it work as an auto failover if fa0 goes down. I am just not sure of how to proceed. All the examples I have seen online work witout NATing in place, plus I have ports open to go to a machine on vlan10, so if someone could point me in the right direction, I would much appreciate it.
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$I9I.$nqNqNaH..3CJ6xtB7FSVR0
enable password 7 106D5E4853441F1C1445
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1 10.0.0.10
ip dhcp excluded-address 10.10.0.1 10.10.0.2
ip dhcp pool Lan1DHCP
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
dns-server 8.8.8.8
ip dhcp pool FamDHCP
network 10.10.0.0 255.255.0.0
default-router 10.10.0.1
dns-server 8.8.8.8
archive
log config
hidekeys
interface FastEthernet0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet2
switchport access vlan 10
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
switchport access vlan 20
interface Vlan1
no ip address
interface Vlan10
ip address 10.0.0.1 255.255.255.0
ip nat inside
interface Vlan20
ip address 10.10.0.1 255.255.0.0
ip nat inside
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet0 overload
ip nat inside source list 102 interface FastEthernet0 overload
ip nat inside source static tcp 10.0.0.200 80 interface FastEthernet0 80
ip nat inside source static tcp 10.0.0.200 443 interface FastEthernet0 443
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
access-list 101 permit tcp any host 0.0.0.0 eq www
access-list 101 permit tcp any host 0.0.0.0 eq 443
access-list 102 permit ip 10.10.0.0 0.0.255.255 any
end
04-23-2017 06:13 PM
Here is an example using a route-map that you can adapt to your configuration.
route-map ISP1 permit 10
match ip address 101
match interface FastEthernet0
route-map ISP2 permit 10
match ip address 102
match interface FastEthernet1
ip nat inside source route-map ISP1 interface FastEthernet0 overload
ip nat inside source route-map ISP2 interface FastEthernet1 overload
