cisco 4331 Router
ittechk4u1
Level 4
Level 4
Hello experts,
1. While ordering Cisco 4331 router(SL-4330-SEC-K9), do we need to order a separate license SL-4330-SEC-K9= or SL-4330-SEC-K9 for crypto/VPN tunnel or its comes together with SL-4330-SEC-K9!!!
2. What is diff between SL-4330-SEC-K9 vs SL-4330-SEC-K9=
or which parts i need to order to have security license included.....
2 Accepted Solutions
ISR4331-SEC/K9 it includes the license and will already be on the router.
Make sure whoever your ordering it off gives you VO2 or higher hardware version  4331 when your ordering them and not a V01 that's effected by the Intel hardware chip issue or you'll be replacing it again in few months as it will fail
http://www.cisco.com/c/en/us/support/web/clock-signal.html
6 Replies 6
Collin Clark
It's easiest if you just order the router with the license you need instead of al' a carte. The part number you want is ISR4331-SEC/K9.
FYI- The difference in part numbers is that if it has an = it is being ordered as a spare part.
K9 means base security (eg SSH)
SEC is full security (eg IPSec, GETVPN)
HSEC is higher throughput security
V is for voice services (eg SRST)
AX is for Application Experience (eg Netflow)
Thanks..
But again..if I order ISR4331-SEC/K9, will SL-4330-SEC-K9 license come along or need to order separately!!!
What is diff between SL-4330-SEC-K9 vs SL-4330-SEC-K9= ?
Thanks in Advance
Thank you
Thanks Mark.
