cisco 1841 dual isp
hello experts,
I need help for configuring two ISPs in a active active mode.
here is the basic connectivity
           (isp1)          (isp2)
          <Router1>   <Router2>
               <<ASA 5520>>
               <CoreSwitch>
Is it possible to configure an Active Active internet connection using two ISPs in the above seniario ?
currently I have configured only one ISP using <ISP1---Router---ASA5520> below is the config
Also suggest me if I can directly terminate both the internet connection to the ASA or is it advisible to use  router ?
Router config
interface FastEthernet0/0
description "WAN IP"
ip address 14.x.x.x 255.255.255.252
speed 100
full-duplex
interface FastEthernet0/1
description "Lan ip"
ip address 14.x.x.x 255.255.255.248
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 14.x.x.1
ip http server
no logging trap
control-plane
Richard Burts
I can not determine from your drawing or from your description whether the 1841 routers each connect directly to an interface on the ASA or whether they connect through a switch. If each router connects directly to an ASA interface then creating an active/active will difficult. If the routers connect through a switch then the routers can communicate directly with each other and that will make it easier to split the traffic and create an active/active mode.
If you will be trying to do this there are some challenges that you will need to plan for:
- where will address translation be done (on ASA or on routers)?
- Will you use a dynamic routing protocol with the ISPs or use static routing?
- arranging for sharing traffic outbound in active/active is under your control and you can probably do it. But what will you arrange with the ISPs to achieve splitting traffic from the ISPs inbound to your network?
Rick
Rick
Initially I had decided to connect the routers directly to ASA but now I  have added a L3 switch between ASA and the routers.
I have added /29 subnet to communicate between Router1, Router2, WAN L3 and ASA.
Currently internet is working on a single ISP. I am still now sure how do I accomplish load balancing can you help me how I proceed further should I use RIP or BGP.
Router1
description "ISP1 WAN IP"
ip address 1.1.1.130 255.255.255.252
duplex full
speed 100
ip address 192.168.99.4 255.255.255.248
duplex auto
speed auto
Ip route 0.0.0.0 0.0.0.0 1.1.1.129
Ip route 2.2.2.1 255.255.255.248 192.168.99.1
Router2
description "ISP2 WAN IP"
ip address 2.2.2.230 255.255.255.252
duplex full
speed 100
duplex auto
speed auto
WAN L3
interface GigabitEthernet1/0/1
switchport access vlan 11
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface Vlan11
ip address 192.168.99.2 255.255.255.248
router rip
version 2
network 1.0.0.0
network 15.0.0.0
network 192.168.99.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.99.1
ip http server
control-plane
line con 0
line vty 0 4
login local
line vty 5 15
login local
ASA
interface GigabitEthernet0/0
speed 1000
duplex full
nameif internet1
security-level 0
ip address 192.168.99.1 255.255.255.248
interface GigabitEthernet0/3
speed 100
nameif inside
security-level 100
ip address 192.168.88.2 255.255.255.0
global (internet1) 1 2.2.2.1 netmask 255.255.255.248----------------- Public IP from ISP2
nat (inside) 1 access-list internet-inside
route internet1 0.0.0.0 0.0.0.0 192.168.99.4 1
Thanks & Regards
Deepak
