Cisco 1841 Ethernet WAN and BGP
bluesheep11
I need to install a cisco 1841 router on an MPLS line running BGP with WAN interface presented as Ethernet 2/10Mb
I have configured many serial WAN links using BGP but never ethernet.  Has anyone an example config I can use as a guide?
bluesheep11 wrote:
Thanks Jon
Do I need to make the nieghbour update source fa0/1?
Mike
Mike
No. You only need to specify update-source if you want to use a different interface for peering than the actual physical interface and you are using the physical interface.
Jon
12 Replies 12
Jon Marshall
Mike
Not sure what you mean by 2/10Mb ? Do you mean you have a fastethernet and want to limit traffic to 20Mbps ? In which case you would need shaping.
Also are you looking for BGP config or not ?
There is nothing special about using ethernet as a WAN link, you would configure it as you would a serial link although obviously you don't need to specify the encapsulation.
Can you clarify the speed thing and exactly what it is config wise you are looking for ?
Jon
Hi Jon
The circuit has a 10Mb access speed but is limited to 2Mb.
With a serial connection I would create the serial interface, create a sub interface and a loopback.  Configure BGP to update the loopback and put the ip unnumbered loopback 0 command against the sub interface.
How would this work when using an ethernet connection rather than a serial interface?
I can do the BGP config, just not sure how it all ties together.
Mike
bluesheep11 wrote:
Hi Jon
Mike
Mike
You will need to use shaping on the ethernet interface. Your provider will undoubtedly be using shaping/policing at their end but you should also do it on yours.
With ethernet you can configure the BGP directly onto the ethernet interface and not bother with a loopback. That's what i did at the last place i worked when we were presented with ethernet by our MPLS provider. Works fine. If you want to use loopbacks for BGP peering you can but then you would need a static route to get to the providers loopback via their ethernet interface and they would need one to get to yours. It's a lot easier just using the ethernet IP address itself.
Note. i'm assuming here that you are configuring standard BGP only ie. you are not configuring MP-BGP for MPLS where a loopback is often needed.
Jon
Hi Jon
I have done the following:
Created FA0/0 with LAN address - 192.168.x.x
Created FA0/1 with no IP address
Created FA0/1.101 with dot1q encap and ip address 10.172.x.x - my loopback address
Set up the bgp peers etc
Created a static route for the bgp peer address to go via FA0/1.101
However I still get no active tcp connection when running "show ip bgp neig"
Am i missing something?
CHeers
Mike
bluesheep11 wrote:
Hi Jon
CHeers
Mike
Mike
Do you mean you have used "ip unnumbered" on the subinterface ?
Not sure what you mean by static route, can you post example ?
Have you tried debugging bgp eg. "debug ip bgp" to see what is happening ?
Finally is there a paticular reason you want to use a loopback ?
Jon
Hi John
Here is what i have:
version 12.4
hostname
boot-start-marker
boot-end-marker
enable secret 5 $1$UCcS$WiB4G6XA.U1sajC.8Rcfs/
enable password!
no aaa new-model
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
ip address 192.168.50.200 255.255.255.0
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
bandwidth 2048
no ip address
duplex auto
speed auto
interface FastEthernet0/1.101
encapsulation dot1Q 20
ip address 10.172.10.202 255.255.255.252
router bgp 64521
no synchronization
bgp log-neighbor-changes
network 192.168.50.0
neighbor 81.144.23.1 remote-as 2856
neighbor 81.144.23.1 ebgp-multihop 3
neighbor 81.144.23.1 update-source FastEthernet0/1.101
no auto-summary
ip forward-protocol nd
ip route 81.144.23.1 255.255.255.255 FastEthernet0/1.101
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
password login
scheduler allocate 20000 1000
end
Mike
I'm confused now
Can't see a loopback in that config but more importantly -
ethernet is not a point to point setup like serial. You have ebgp-multihop 3 which suggests that the neighbor address is not directly connected ? By using that static route -
you are simply telling your router to arp out for 81.144.23.1 which won't work because even if it was connected how would it route it back, it is on a different network.  Lets step back a bit -
1) if the connection is ethernet what is the provider IP address of their ethernet interface ? They should have provided you with the IP of their ethernet interface and then given you an IP to use on your ethernet interface - did this not happen.
2) Why do you want to use a subinterface rather than simply apply the IP to the fa0/1 interface ?
Is 81.144.23.1 the address of the ISP ethernet interface  ? or is the ISP address a 10.172.10.x address ?
Jon
Hi John
OK I think I know where I am going wrong.
The ethernet interface on the PE router is 10.172.10.201
I am used to working with serial hense why I used a sub interface, I removed the loopback based on your previous suggestion.
81.144.23.1 is the address of the peer BGP router.
Does that make sense?
Cheers
Mike
Mike
Okay, that makes more sense.
Make these changes to your config -
int fa0/1
router bgp 64521
no neighbor 81.144.23.1 update-source fa0/1.101
ip route 81.144.23.1 255.255.255.255 10.172.10.201
If you wanted to use a loopback then you could but then the ISP would need to add a route on their router to get your loopback via fa0/1 interface on your router. So you may want to do that later but lets just test this.
Jon
Thanks Jon
Mike
bluesheep11 wrote:
Thanks Jon
Mike
Mike
Jon
OK Thanks.
Thanks for your help.
Cheers
Mike
