10-07-2010 03:14 AM - edited 03-04-2019 10:01 AM
Hello experts,
i have a problem with a cisco 1841 router. I try to bbot the device but it hangs after loading the IOS. Here is the ooutput of the boot process:
Initializing ATA monitor library.......
program load complete, entry point: 0x8000f000, size: 0xc100
program load complete, entry point: 0x8000f000, size: 0xec6ec4
Self decompressing the image : #################################################
################ [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
0X00020000 Crypto module pools
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 7408324 bytes to IO Memory.
PMem allocated: 118489088 bytes; IOMem allocated: 15728640 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-IPBASEK9-M), Version 12.4(3j), RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 13-Dec-07 19:26 by stshen
Image text-base: 0x6008873C, data-base: 0x616013A0
Port Statistics for unclassified packets is not turned on.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
After this point the router hangs. can you tell me if this is a hardware fault or can fix the issue?
Thank you.
10-07-2010 04:36 AM
Can you tell us what WICS, cables or USB devices you have installed on this router (if any)? I would start troubleshooting this issue by first removing the WIC's and not using the USB port. If the router is able to boot up, then replace the modules one at a time to isolate which is causing the issue. In the past, we have seen devices connected to the USB port would cause this issue so start there first. You can also break into rommon when the router is booting (press ctrl-break during the boot sequence) then change the configuration register to ignore the statup-config by using the command "confreg 0x2142". Once you change the config register, boot the router by typing "i". If the router boots while ignoring the config, then once it is up take a close look at the startup-config to see if you can tell what is wrong (again, concentrate on the location of the IOS image - is it on a USB or the internal Flash and any installed modules).
10-07-2010 05:57 AM
Hi and thank you for your reply.
I´ve changed the confreg as told but there is now difference. The router has no WICs intalled and the IOS is on a Comptact Flash Card.
Here is the output once again:
System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
Initializing cache
Initializing TLB and required TLB entries
Correcting the backup nv_flash
Reading monitor variables from NVRAM
Init Rommon Upgrade NVRAM Vars
Init Rommon Upgrade startPLD version 0x10
GIO ASIC version 0x127
Reset IO
Enabling interrupts
Reading cookie
Initializing main memory
Sizing NVRAM
Initializing PCI subsystem
Exiting init
c1841 processor with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
rommon 1 > confreg 0x2142
You must reset or power cycle for new config to take effect
rommon 2 > i
PLD version 0x10
ID MEMORY_REQ TYPE
Allocating additional 7404574 bytes to IO Memory.
cisco Systems, Inc.
SOFTWARE (fc1)
Image text-base: 0x6008873C, data-base: 0x616088D0
export@cisco.com.
10-07-2010 06:13 AM
Sorry you are still having problems. It is possible that the router is defective, but before going that route lets try a couple more things. Have you removed all cables and USB devices from the router then tried booting? Can you ensure the flash is readable in rommon by issing the "dir flash:" command? Can you try a different compact flash and or IOS image? If all of that fails, then I would suggest opening a case with the TAC.
Tim
10-07-2010 06:37 AM
Hi Tim,
yeas, i´ve tried to do that but i almost think this is a hardware failure. From ROMMON i can see the content of the flashcard:
rommon 1 > dir flash:
Directory of flash:
2 15495268 -rw- c1841-ipbasek9-mz.124-3j.bin
So i think the only thing i can do is open a TAC...:(
Thank you.
