Cisco 1841: High CPU utilization when Skype-call over VPN
Anton Pestov
Cisco IOS Software, 1841 Software (C1841-ADVENTERPRISEK9-M), Version 15.1(4)M2, RELEASE SOFTWARE (fc1)
When the client on a Branch Office LAN realizes calls to skype, there is a sharp loading of CPU on Branch router Cisco1841 (all Inet traffic goes through DMVPN-Tunnel Interface to proxy on Central Office).
CPU utilization for five seconds: 89%/81%; one minute: 44%; five minutes: 41%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
121    30971272    10952019       2827  6.65%  5.59%  5.75%   0 IP Input
   2      125984      229295        549  1.28%  0.12%  0.10%   0 Load Meter
  96     1774568   141763543         12  0.64%  0.75%  0.78%   0 Ethernet Msec Ti
117      515872    35077439         14  0.56%  0.17%  0.16%   0 IPAM Manager
336     2617980   276339056          9  0.48%  1.70%  1.79%   0 IP SLAs Responde
203      929984   275753650          3  0.24%  0.79%  0.86%   0 HQF Shaper Backg
330      796120    55876200         14  0.16%  0.26%  0.28%   0 MFIB_mrib_write
314      414120    11711507         35  0.08%  0.12%  0.10%   0 IGMP Input
315      966264    25445473         37  0.08%  0.21%  0.23%   0 PIM Process
240      278164    35693249          7  0.08%  0.09%  0.08%   0 MMON MENG
TLLN-CE1#sh ip flow top-talkers
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP Bytes
Tu253         10.101.0.20     Vl1           10.108.1.32     06 1F90 C709  6974K
Tu253         10.101.0.20     Vl1           10.108.1.32     06 1F90 C72E  3289K
Vl1           10.108.1.32     Tu254*        10.101.0.20     06 C709 1F90  1568K
Tu254         10.100.0.14     Vl1           10.108.1.34     06 0D3D 0408  1311K
Tu253         10.101.1.233    Vl1           10.108.1.37     06 0D3D 040A   541K
5 of 5 top talkers shown. 44 flows processed.
FastEthernet 0/0 - WAN Interface (for Tunnel Source):
TLLN-CE1#sh int f0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 58bc.2771.5f8e (bia 58bc.2771.5f8e)
  Description: WAN
  Internet address is x.x.x.x/y
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 254/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:13, output 00:00:00, output hang never
  Last clearing of "show interface" counters 04:12:34
  Input queue: 43/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  30 second input rate 1909000 bits/sec, 244 packets/sec
  30 second output rate 356000 bits/sec, 30 packets/sec
     1875022 packets input, 808226627 bytes
     Received 535 broadcasts (0 IP multicasts)
     6431 input errors, 0 CRC, 0 frame, 0 overrun, 6431 ignored
     0 watchdog
     763186 packets output, 200182523 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
All Skype traffic application auto mark as DSCP EF, and then router applies the next outbound policy on WAN Fast0/0:
class-map match-any CLASS-VOICE
match ip dscp ef
policy-map POLICY-QOS-OUT
description *** Global QoS Policy ***
class CLASS-ROUTING
  bandwidth percent 3
class CLASS-VOICE
  priority percent 18
class CLASS-VIDEO-CONF
  priority percent 15
class CLASS-STREAM-VIDEO
  bandwidth percent 10
class CLASS-MISSION-CRIT
  bandwidth percent 12
  random-detect dscp-based
  random-detect dscp 25 32 40
class CLASS-VOICE-CONTROL
  bandwidth percent 2
class CLASS-TRANSACT
  bandwidth percent 8
class CLASS-NETWORK-MGMT
  bandwidth percent 2
class CLASS-BULK
  bandwidth percent 8
  random-detect ecn
class CLASS-SCAVENGER
class class-default
  fair-queue
policy-map POLICY-INET-10M-OUT
class class-default
  shape average 8500000 850000
  service-policy POLICY-QOS-OUT
interface FastEthernet0/0
description WAN
ip address x.x.x.x y.y.y.y
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
ip verify unicast reverse-path allow-self-ping 150
load-interval 30
duplex auto
speed auto
service-policy output POLICY-INET-10M-OUT
TLLN-CE1#sh ip traffic
IP statistics:
  Rcvd:  102808 total, 3682 local destination
         0 format errors, 0 checksum errors, 252 bad hop count
         0 unknown protocol, 0 not a gateway
         0 security failures, 0 bad options, 1337 with options
  Opts:  0 end, 0 nop, 0 basic security, 0 loose source route
         0 timestamp, 0 extended security, 0 record route
         0 stream ID, 0 strict source route, 1337 alert, 0 cipso, 0 ump
         0 other
  Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
         90 fragmented, 180 fragments, 0 couldn't fragment
  Bcast: 65 received, 1 sent
  Mcast: 1476 received, 797 sent
  Sent:  100833 generated, 451516 forwarded
  Drop:  0 encapsulation failed, 0 unresolved, 0 no adjacency
         0 no route, 0 unicast RPF, 0 forced drop
         0 options denied
  Drop:  0 packets with source IP address zero
  Drop:  0 packets with internal loop back IP address
         0 physical broadcast
  Reinj: 0 in input feature path, 0 in output feature path
ICMP statistics:
  Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 190 unreachable
        0 echo, 0 echo reply, 0 mask requests, 0 mask replies, 0 quench
        0 parameter, 0 timestamp, 0 timestamp replies, 0 info request, 0 other
        0 irdp solicitations, 0 irdp advertisements
        0 time exceeded, 0 info replies
  Sent: 0 redirects, 0 unreachable, 0 echo, 0 echo reply
        0 mask requests, 0 mask replies, 0 quench, 0 timestamp, 0 timestamp replies
        0 info reply, 0 time exceeded, 0 parameter problem
TCP statistics:
  Rcvd: 1018 total, 0 checksum errors, 0 no port
  Sent: 1067 total
BGP statistics:
  Rcvd: 0 total, 0 opens, 0 notifications, 0 updates
        0 keepalives, 0 route-refresh, 0 unrecognized
  Sent: 0 total, 0 opens, 0 notifications, 0 updates
EIGRP-IPv4 statistics:
  Rcvd: 0 total
  Sent: 0 total
PIMv2 statistics: Sent/Received
  Total: 336/685, 0 checksum errors, 0 format errors
  Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0,  Hellos: 183/181
  Join/Prunes: 105/352, Asserts: 1/105, grafts: 47/0
  Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
  Queue drops: 0
  State-Refresh: 0/0
IGMP statistics: Sent/Received
  Total: 299/713, Format errors: 0/0, Checksum errors: 0/0
  Host Queries: 90/30, Host Reports: 209/358, Host Leaves: 0/0
  DVMRP: 0/0, PIM: 0/0
  Queue drops: 0
UDP statistics:
  Rcvd: 907 total, 0 checksum errors, 41 no port
  Sent: 974 total, 0 forwarded broadcasts
OSPF statistics:
  Last clearing of OSPF traffic counters 00:29:47
  Rcvd: 169 total, 0 checksum errors
        125 hello, 0 database desc, 0 link state req
        31 link state updates, 13 link state acks
  Sent: 154 total
        17 link state updates, 12 link state acks
ARP statistics:
  Rcvd: 367 requests, 0 replies, 0 reverse, 0 other
  Sent: 0 requests, 239 replies (0 proxy), 0 reverse
  Drop due to input queue full: 0
What can cause sharp loading of CPU? ...throughput performance 1841, it seems, allows to process traffic
paolo bevilacqua
You have some configuration complexity, try simplifying.
paolo bevilacqua
Configuration optimum. When I apply shaping policy for Branch-client on CO-router (shape average 500k), then  loading of Branch-router 1841 CPU became less...
Skype-client connect to virtual NLB IP Proxy (from two FTMG in cluster), if Skype-client connect to phisycal IP one of two FTMG-proxy, that problems with loading of CPU aren't present!
