MLPPP with Higher MTU then 1500 without Fragmentation
Samuel De Wever
Dear,
I am trying to set-up an MLPPP sessie with an MTU higher than 1500 but without fragmentation. The link between PE and CPE supports MTU upto 1530
Concrete situation in testlab is as following
Cisco 7200 with NPE-400 acting as BRAS connected to an Cisco 2900 on his FastEthernet0/1
MTU size on the FastEthernet0/1 is 1530
MTU size on the Gig0/0 of the 2900 is 1530 as well
PE Config
interface FastEthernet0/1
mtu 1530
no ip address
speed auto
duplex auto
pppoe enable group radius-1
no cdp enable
end
bba-group pppoe radius-1
virtual-template 2
tag ppp-max-payload minimum 1492 maximum 1600
interface Virtual-Template2
mtu 1510
ip unnumbered FastEthernet0/0
peer default ip address pool default
keepalive 20
ppp mtu adaptive
ppp lcp echo mru verify
ppp authentication pap radius-1
ppp authorization radius-1
ppp accounting radius-1
ppp multilink
ppp multilink fragment disable
ppp multilink mrru local 1510
CPE Config
interface GigabitEthernet0/0
mtu 1530
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
end
interface Dialer0
mtu 1510
ip address negotiated
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username ********* password 0 ***************
ppp multilink
The session comes online and I am seeing an MTU of 1510 on both sides (CPE and PE)
PE
Virtual-Access4 is up, line protocol is up
  Hardware is Virtual Access interface
  Interface is unnumbered. Using address of FastEthernet0/0 (188.118.4.252)
  MTU 1510 bytes, BW 200000 Kbit/sec, DLY 100000 usec,
  Encapsulation PPP, LCP Open, multilink Open
  Open: IPCP
  MLP Bundle vaccess, cloned from Virtual-Template2
  Vaccess status 0x44, loopback not set
  Keepalive set (20 sec)
  DTR is pulsed for 5 seconds on reset
  Last input 00:00:08, output never, output hang never
  Last clearing of "show interface" counters 00:00:45
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     15 packets input, 9568 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     15 packets output, 9982 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
CPE
  MTU 1510 bytes, BW 112 Kbit/sec, DLY 20000 usec,
  Stopped: CDPCP
  Open: IPCP
  MLP Bundle vaccess, cloned from Dialer0
  Keepalive set (10 sec)
  Interface is bound to Di0 (Encapsulation PPP)
  Last input 00:00:14, output never, output hang never
  Last clearing of "show interface" counters 00:00:53
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 84 kilobits/sec
     16 packets input, 9616 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     16 packets output, 10054 bytes, 0 underruns
So far so good, however, I am not able to transport any packet bigger then 1500 with DF-Flag enabled
yourname#ping 188.118.4.252 size 1500 df-bit
Sending 5, 1500-byte ICMP Echos to 188.118.4.252, timeout is 2 seconds:
Packet sent with the DF bit set
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
yourname#ping 188.118.4.252 size 1501 df-bit
Sending 5, 1501-byte ICMP Echos to 188.118.4.252, timeout is 2 seconds:
Success rate is 0 percent (0/5)
yourname#
Any ideas?
Samuel De Wever
Found an solution, however, It looks to be a bug.
When applying Cisco-avpair += lcp:interface-config#1=ip mtu 1510 trught radius on the user, I am able to ping upto 1510.
As well as I enter ip mtu 1510 under the Virtual Template after the session has been setup.
