cisco 1841 : ping not possible
watocisco
1841 is between 2 network at left 10.0.XX 255.255.0.0 and at right 10.254.0.X 255.255.255.0 routage table is ok but a computer at left with 10.0.0.76 not ping a computer a right 10.254.0.2 !!!!!!!!!
not firewall so what is the probleme please ?
Richard Burts
Eric
In a situation such as you describe the first thing I would check would be to verify that the router is able to ping both PCs. This will verify local connectivity and reachability. It will also check on the possibility that the PCs may be running a firewall which is denying ping.
If the router can ping both PCs then the next thing that I would check as a possible problem is what do the PCs have configured as their default gateway (also check to verify that the IP address and mask configured are correct). Many times this kind of problem is a mis-configured default gateway.
Rick
Rick
12 Replies 12
Richard Burts
Eric
Rick
Rick
default gateway are ok, so both pc can ping the opposed address on the router (ex : a left PC 10.0.0.76 can ping 1841 port 10.202.0.133 but not ping the PC 10.202.0.2 behind the router)
anyway router can ping both pc
Eric
There is a change from your first post to this one. In the first post the second address range was 10.254.0.0 and now it seems to be 10.202.0.0. Is there any significance to this change?
Is there any access list on the router which could be affecting the ping?
Rick
Rick
oh sorry not 10.202.0.0 but really 10.254.0.0
no access list on the 1841
Eric
Can you post the config of the router? And also can you post the output of show ip route from the router?
Rick
Rick
Building configuration...
Current configuration : 5127 bytes
version 12.4
hostname WATO_CISCO1841_ROOT_PART_WWW
boot-start-marker
boot-end-marker
interface FastEthernet0/0
description LAN_WATO$FW_INSIDE$$ETH-LAN$
ip address 10.0.254.250 255.255.0.0
ip access-group sdm_fastethernet0/0_in in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip inspect SDM_LOW in
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
description LS_SEDIRSI
interface FastEthernet0/1/1
description NUMERIS_CATP
interface FastEthernet0/1/2
shutdown
interface FastEthernet0/1/3
description WWW_FW_VPN
switchport access vlan 99
switchport trunk native vlan 99
interface Vlan1
description LS_PART_EXT$FW_OUTSIDE$
ip address 10.250.0.33 255.255.255.0
ip access-group 100 in
no ip route-cache
interface Vlan99
ip address 10.254.0.133 255.255.255.0
ip access-group sdm_vlan99_in in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 permanent
ip route 10.0.0.0 255.255.0.0 FastEthernet0/0 permanent
ip route 10.250.0.0 255.255.255.0 Vlan1 permanent
ip route 10.254.0.0 255.255.255.0 Vlan99 permanent
ip flow-top-talkers
top 5
sort-by packets
cache-timeout 1
ip http server
ip http authentication local
ip http secure-server
ip access-list extended sdm_fastethernet0/0_in
remark SDM_ACL Category=1
permit icmp any any echo
permit ip any any
ip access-list extended sdm_vlan99_in
permit icmp any any echo-reply
permit ip any any
logging trap debugging
logging 10.254.0.2
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 10.0.0.0 0.0.255.255 any
access-list 100 permit icmp any host 10.250.0.33 echo-reply
access-list 100 permit icmp any host 10.250.0.33 time-exceeded
access-list 100 permit icmp any host 10.250.0.33 unreachable
access-list 100 deny ip 10.0.0.0 0.255.255.255 any
access-list 100 deny ip 172.16.0.0 0.15.255.255 any
access-list 100 deny ip 192.168.0.0 0.0.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip host 0.0.0.0 any
access-list 100 deny ip any any log
WATO_CISCO1841_ROOT_PART_WWW#show ip route
Default gateway is not set
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
Im in france im back tomorrow at 10H AM greenwich
thank you see you tomorrow
Eric
Thank you for posting the router config and the output of show ip route. Seeing the config does help confirm that there does not appear to be an access list issue which could cause the problem that you are experiencing.
The output of show ip route is unexpected - because it is empty. I would expect to see at least the connected interfaces. I suspect that your problem is related in some way to the fact that the routing table is empty.
Could you post the output of show ip interface brief? Perhaps this will shed some light on what is going on.
Rick
Rick
WATO_CISCO1841_ROOT_PART_WWW#show ip interface brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 10.0.254.250 YES NVRAM up up
FastEthernet0/1 unassigned YES NVRAM administratively down down
FastEthernet0/1/0 unassigned YES unset up down
FastEthernet0/1/1 unassigned YES unset up down
FastEthernet0/1/2 unassigned YES unset administratively down down
FastEthernet0/1/3 unassigned YES unset up up
Vlan99 10.254.0.133 YES TFTP up up
NVI0 unassigned NO unset up up
enable "ip routing" in global config mode. it will solve problem hope fully..
Rate it if works...
*aijaz*
i seen thank you
