05-22-2009 10:03 PM - edited 03-04-2019 04:51 AM
I am using cisco 1841 for my internet purpose.i cant able to send mail attachments.Please help me.my config as follows
#sh run
Building configuration...
Current configuration : 4833 bytes
version 12.4
boot-start-marker
boot system flash c1841-advsecurityk9-mz.124-11.XJ4.bin
boot-end-marker
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 192.168.2.254 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address x.x.x.x 255.255.255.248
duplex auto
speed auto
interface Serial0/0/0
ip address b.b.b.b 255.255.255.252
ip nat outside
ip route 0.0.0.0 0.0.0.0 172.24.67.210
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool INT x.x.x.x x.x.x.x netmask 255.255.255.248
ip nat inside source list 5 pool INT overload
access-list 5 permit 192.168.2.0 0.0.0.255
05-23-2009 03:24 AM
try to replace the standard acl with extended and allow smtp:
access-list 101 permit tcp 192.168.2.0 0.0.0.255
05-23-2009 06:21 PM
S mohana
With all due respect for John's suggestion I do not see why it would be better to go with the extended access list. And if you configure as he has suggested then the ONLY thing that would get translated is email.
I believe that we need to understand some things about your situation before we can figure out the problem. Your post says that you can not send email attachments. I wonder if that is exactly what you meant? Can you send email that does not have attachments?
It would also be very helpful to know where you are attempting to send Email from? Is it FastEther0/0 or from FastEther0/1? And where is the email server that you are attempting to send to?
Knowing these things would give us a start in looking for your problem.
Rick
