configure DDNS
tiger_401
Dear All,
I have a cisco router 2811. I need to configure Dynamic DNS on my router. Can any body send me a sample configuration.
Will be very grateful to you..
Malik.
5 Replies 5
Thanks for your response...but boss i need the config only..is it possible for you to send me the exact configuration for configuring dynamic DNS in a router.
Your consideration in this regard will highly be commendable.
Malik.
Hi, if you want somebody to write configurations for you, I recommend you hire a reputable consultant.
Actually i didnt mean this. I thought if u have sample configuration you can just copy paste here..that all...
Malik...
As mentioned before, there are examples in the documentation, plus these are commented for your ease of understanding.
