Cisco 1841 support BGP
kumarpmt83
I have cisco 1841 router in my office.
In that router we configured MPLS bgp with two different service provider.
Config:
router bgp 58001
no synchronization
bgp log-neighbor-changes
network 10.30.120.0 mask 255.255.254.0
neighbor 10.237.68.15 remote-as 65600
neighbor 10.237.68.15 description ***TULIP WAN***
neighbor 10.237.68.15 soft-reconfiguration inbound
neighbor 192.168.12.36 remote-as 9725
neighbor 192.168.12.36 description ***BSNL WAN***
neighbor 192.168.12.36 soft-reconfiguration inbound
no auto-summary
We can't able to use the different service provider at the sametime.
My question:
Cisco 1841 is support two different AS ???
12 Replies 12
Richard Burts
the 1841 should be capable of supporting 2 ISP with 2 AS numbers, depending on how many prefixes are advertised by the peers (and depending on how much memory is present in them).
I wonder if your issue is related to the AS number of the peer shown in your config.
Rick
Rick
In that router we are not configured any prefixes.
Our 10.30.110.0 advertised to both Tulip and bsnl.
Both link is not working at the same time.After i shutdown any one of the port it is working.
We want all traffic should be working with Tulip as primary and if any problem in that tulip it should be take the BSNL link.
Can u tell me the solution??
We do not have enough information to know what the problem is, much less to be able to tell you the solution. A good starting place would be to post the configuration of the router.
Rick
Rick
Building configuration...
Current configuration : 4116 bytes
version 12.4
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
boot-start-marker
boot system flash c1841-advsecurityk9-mz.124-24.T4.bin
boot-end-marker
logging message-counter syslog
logging buffered 51200 notifications
no aaa new-model
clock timezone India 5 30
dot11 syslog
ip source-route
--More--
ip cef
isdn switch-type basic-net3
crypto pki trustpoint TP-self-signed-2080122312
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2080122312
revocation-check none
rsakeypair TP-self-signed-2080122312
archive
log config
  hidekeys
--More--
interface FastEthernet0/0
description ***** LAN *****$ETH-LAN$
ip address 10.30.120.100 255.255.254.0
duplex auto
speed auto
keepalive 1000
interface FastEthernet0/1
description $$TULIP-WAN$$
bandwidth 512
ip address 10.237.68.14 255.255.255.252
ip accounting output-packets
duplex auto
speed auto
interface BRI0/0/0
no ip address
encapsulation hdlc
shutdown
isdn point-to-point-setup
interface Serial0/1/0
description #### BSNL WAN  ####
ip address 192.168.12.35 255.255.255.252
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip virtual-reassembly
encapsulation ppp
load-interval 30
no fair-queue
router bgp 58001
no synchronization
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
snmp-server community startrac RW 55
snmp-server community h0Wd@r3U RW
snmp-server enable traps snmp authentication linkdown linkup
snmp-server enable traps envmon
snmp-server enable traps bgp
snmp-server enable traps config
snmp-server enable traps cpu threshold
snmp-server host 10.10.42.20 h0Wd@r3U
what does it mean "Both link is not working at the same time" exactly?
BGP sessions down?
Or some routing loop?
I\d be careful here - your AS might become a transfer AS for both providers - don't forget you are adverting all prefixes received from on eBGP neighbor to the other neighbor.
So I'd try to use an oytgoing route-map towards both neigbors permitting only the  10.30.110.0 prefix to be advertised.
HTH,
Milan
As per ur Instructions i should advertise the 10.30.120.0 to both the neighbor which ISP route they take???
Anyother configuration is needed for this requirement???
you could add to your config for example:
ip prefix-list adv_to_providers seq 5 permit  10.30.120.100/23
route-map outging permit 10
match ip add prefix-list adv_to_providers
route-map from_tulip permit 10
set local-preference 200
router bgp 58001
neighbor 10.237.68.15 route-map from_tulip in
neighbor 10.237.68.15 route-map outgoing out
neighbor 192.168.12.36 route-map outgiong out
This way you would advertise only the 10.30.120.100/23 to both providers.
And the prefixes received from Tulip would be preferred, so you would use Tulip for outgoing traffic.
Are some other sites connected to both providers?
If yes, you might need to tune prefix preference on that sites to prefer Tulip, too.
HTH,
Milan
Thanks for ur support.
We are using the Tulip for all users access the application in HO.
BSNL link for using our CCTV camera in that office.
We are configured 10.30.120.120 in the CCTV DVR.
All traffic should working in TULIP expect that 10.30.120.120.
CCTV Traffic should go only for BSNL link.
If any case Tulip Link down,we want allow all  the traffic to BSNL LINK for temporary.
After Tulip link came means traffic should go to Tulip.
The above configuration u given  is enough for this requirement???
Of course it's not enough!
You would probably need to advertise a host prefix  10.30.120.120/32 to achieve that.
And handle incoming/outgoing traffic for this host special way.
IMHO, you should hire a skilled professional to make the configuration fulfilling all your requirements.
This forum can give you hints, but not perform a detailed configuration for you!
BR,
Milan
Thanks for ur advice.
Last question
i want the tulip to be a primary route in the time of both link available.
can i give like this for my requirement.
neighbor 10.237.68.15 weight 100.
If i give like this it will take the Tulip route as primary.
Sure.
It will have similar effect as the local preference increase I used in my example route-map.
BR,
Milan
Now in my client end  router 1841 both ISP working.
But i am not able to ping the both WAN  IP through My system.System in HO
But client end both ISP is pinging  through my HO Router.
If i shut any one of the ISP in client end  that another ISP is pinging through my system.
where is the problem??any problem in the client end router.
