Shape Output Traffic 2821
Hi All
I have a Cisco 2821 with ios Version 12.4(21). On that router I have a WAN link that is 550mbit dual.
The interface is 1000FD so i need to shape my output traffic to max 550mbit - otherwise my ISP policing is dropping the traffic.
I've looked at this document http://www.cisco.com/en/US/docs/ios/12_0/qos/configuration/guide/qcgts.html and i'm trying to use this interface command:
traffic-shape rate
But the router wont accept rate value 550000000 that should be 550mbit in bits/s
Is it not possible to shape the traffic to 550mbit on the 2821 router?
Best Regards,
Steffen
Your current traffic rate is  16Mbps , below the rate where shaping is triggered ( 550Mbps ).
The output is correct.
Dan
10 Replies 10
Hi ,
You can try using class based shaping :
policy-map WAN
class class-default
   shape average percent 55
int gix/x
service-policy out WAN
Dan
HI Dan
That seems to Work. The 55 percent: Is that 55% of the speed or bandwidth command on the interface?
/Steffen
Hi Steffen,
Is the percent of the bandwidth command ( in your case also the speed of the interface ).
You can verify it with
show int x/x | i BW
Dan
interface GigabitEthernet0/0
description Esbjerg-1 WAN
bandwidth 550000
ip address 172.20.1.1 255.255.255.0
ip route-cache flow
duplex full
speed 1000
service-policy output WAN-SHAPE
My Bandwidth is actually set to 550mbit - its the link speed that is set to 1000mbit. So with this shapeing, in need to set that bandwidth to 1000 as well as the speed right?
Or set the shaping percent to 100.
also you can hardcode the value.
shape average 550000000
Dan
Ha Ha of course... 🙂
Why is it saying "shaping no" when showing the policy map for my interface?
Dan
Thank You!
With pleasure.
