Cisco 1841 with additional ethernet adapter
I have bought a Cisco 1841 with an additional ethernet adapter (so it has 3 ethernet interfaces). But when I enter the router operative system I see only 2 ethernet interfaces, the budled FastEthernet0/0 and FastEthernet0/1. It seems that the current operative system of the router can't recognize the additional adapter. I can't find what version of the operative system or additional software is needed (at this moment the operative system is 12.4 but I can't see what specific version of 12.4). Please, can anyone help me ?
Thanks a lot.
Riccardo
You need to upgrade your IOS. You have 12.4-3 whereas you need at least 12.4(15)T.
Hardware support for the HWIC-1FE card was added in the T train in 12.4.
Jon
Jon Marshall
Riccardo
Is the additional ethernet card a HWIC-IFE ?
If so you need a minimum of 12.4(15)T for your IOS.
If you are unsure of your IOS please post output of "sh ver"
Jon
Hello Jon, thanks for you response.
The configuration of my router is:
MODULAR ROUTER W/2XFE, 2 WAN S LOTS, 32FL/128 DR Modular Router w/2xFE, 2 WANs
hwic-1fe= HWIC ONE ROUTED PORT
hwic-1t= 1-PORT SERIAL WAN INTERFACE CAR
The ouput of "sh ver" is:
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(3i), RELEASE SO
FTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 18:17 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
yourname uptime is 4 hours, 2 minutes
System image file is "flash:c1841-ipbase-mz.124-3i.bin"
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FCZ1244949Y
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Riccardo
Riccardo
Jon
