cisco 1841 with no service password-recovery
porrameds
I use c1841 with IOS adventerprisek9-mz.124-15.T2.bin and try to configure with "no service password-recovery" command but I see only "no service password-encryption" command on the router.
I also check with Cisco Feature Navigator and there is service password-recovery feature support with this IOS that I mention.
I don' t know why I can not see this "no service password-recovery" command on my router.
Could you please help me and advice.
Thank you in advance
porramed
2 Accepted Solutions
Hamed Z
it is a ROMMON security mechanism and highly depend on your ROMMON Version.
Change your ROMMON to Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
6 Replies 6
milan.kulik
Level 10
Level 10
what about your ROMMON version?
See "You must download and install ROM monitor (ROMMON) version 12.2(11)YV1 before you can use this feature." here:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_cfg/configuration/15-sy/sec-usr-cfg-15-sy-book/sec-no-svc-pw-recvry.html#GUID-5C387826-455E-41E4-88C2-F6D6412FA9BA
Best regards,
Milan
Here is my router 1841 information.   I see that ROM is version 12.3(8r)T9 as following.  Do I need to change the ROM version?
Router#sh ver
Cisco IOS Software, 1841 Software (C1841-ADVENTERPRISEK9-M), Version 12.4(11)T2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 30-Apr-07 15:12 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Router uptime is 4 minutes
System returned to ROM by reload at 02:31:33 UTC Tue May 27 2014
System image file is "flash:c1841-adventerprisek9-mz.124-11.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 1841 (revision 6.0) with 248832K/13312K bytes of memory.
Processor board ID FHK101520WF
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Router#
Thank you all friend.   After I change to new ROM as you recommended.  It work fine.
I can issue no service password-recovery command on my router.
Thank you very much
porramed
Hamed Z
Leo Laohoo
What for?  Even if you enable, I am still able to.
