cisco 1841
gowdakssujan
Does cisco 1841 support WAN??
2 Accepted Solutions
Jaderson Pessoa
Yes, support.
The modular architecture on the Cisco 1841 router supports HWIC slots. The newly designed high-speed WAN interface slots significantly increase the data-throughput capability (up to 800-Mbps aggregate). Table 6 lists the High Speed WAN Interface cards supported on the Cisco 1841.
• Both slots on the Cisco 1841 router are HWIC slots and provide compatibility with WICs and multiflex trunk (VWICs) interface cards
(for data only).
Look this for more detail: https://www.cisco.com/c/en/us/products/collateral/routers/1800-series-integrated-services-routers-isr/product_data_sheet0900aecd8016a59b.html
Jaderson Pessoa
*** Rate All Helpful Responses ***
Seb Rupik
Hi there,
Yes, the 1841 is an ISR G1 router. Slow by todays standards but definitely a WAN router. Take a look at the array of WIC cards it supports:
https://www.cisco.com/c/en/us/products/routers/1800-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
cheers,
Seb.
Jaderson Pessoa
Yes, support.
(for data only).
Jaderson Pessoa
Seb Rupik
Hi there,
cheers,
Seb.
Does any of the L3 switches support serial interface ???
Yes, the most common modules were the HWIC-1T and HWIC-2T .
