IPSec to AWS/VyOS
madheff
Hi All,
Hoping someone can offer some advice. I have to get a Cisco 892 running 15.6(2)T1 to connect to a VyOS running at AWS. I initially got this working fine, however after 3 weeks the connection failed. I can see P1 working OK, however it then goes down and P2 its up but my LAN routes seem to be assigned to P1?
The relevant config is:
crypto keyring PHILIPS
  local-address GigabitEthernet8
  pre-shared-key address X.X.X.X key {crypto-key}
crypto isakmp policy 30
 encr aes 256
 hash sha256
 authentication pre-share
 group 5
 lifetime 28800
crypto isakmp profile PHILIPS-AWS
   keyring PHILIPS
   self-identity address
   match identity address X.X.X.X 255.255.255.255
   keepalive 120 retry 15
   initiate mode aggressive
crypto ipsec transform-set Philips2 esp-aes 256 esp-sha256-hmac
 mode tunnel
crypto map clientmap 20 ipsec-isakmp
 set peer X.X.X.X
 set transform-set Philips2
 set isakmp-profile PHILIPS-AWS
 match address 129
ip route 172.34.10.159 255.255.255.255 X.X.X.X
access-list 129 permit ip 192.168.150.0 0.0.0.255 host 172.34.10.159
access-list 129 permit ip host 172.34.10.159 192.168.150.0 0.0.0.255
Here is the state of the session:
Interface: GigabitEthernet8
Session status: DOWN
Peer: X.X.X.X port 500
  IPSEC FLOW: permit ip host 172.34.10.159 192.168.150.0/255.255.255.0
        Active SAs: 0, origin: crypto map
  IPSEC FLOW: permit ip 192.168.150.0/255.255.255.0 host 172.34.10.159
Profile: PHILIPS-AWS
Session status: UP-IDLE
Peer: X.X.X.X port 4500
  Session ID: 0
  IKEv1 SA: local Y.Y.Y.Y/4500 remote X.X.X.X/4500 Active
I would normally expect to see the non NAT-ed LAN mappings to appear in the 4500 session.
I am excluding 192.168.150.0/24 to host 172.34.10.159 from NAT.
Here are the SAs
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
Y.Y.Y.Y  X.X.X.X   QM_IDLE           2017 ACTIVE PHILIPS-AWS
that looks good. I am currently working on the exact same thing, do you still need the configuration ? Probably not, since you have it working...
VTI is the preferred method...
6 Replies 6
you mightb be better off using a VTI. Post the full configuration of your Cisco...
Here you go:
version 15.6
service timestamps log datetime msec localtime
hostname 247care.qld
boot-start-marker
boot-end-marker
enable secret secret
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization network vpngroup local
aaa session-id common
ethernet lmi ce
clock timezone ACST 10 30
ip inspect name FW echo
ip inspect name FW ntp
ip inspect name FW syslog
ip inspect name FW tcp
ip inspect name FW udp
ip inspect name FW snmp
ip inspect name FW icmp
ip inspect name FW dns
ip inspect name TELSTRA echo
ip inspect name TELSTRA ntp
ip inspect name TELSTRA syslog
ip inspect name TELSTRA tcp
ip inspect name TELSTRA udp
ip inspect name TELSTRA snmp
ip inspect name TELSTRA icmp
ip inspect name TELSTRA dns
ip inspect name TELSTRA isakmp
ip cef
no ipv6 cef
license udi pid C897VA-K9 sn FGL220291MH
username admin secret 5 $1$9igw$zCgew5UHOMCh67qRyAzEc/
controller VDSL 0
track 1 ip sla 1 reachability
policy-map TELSTRA_50mb
 class class-default
  shape average 49000000 640000 0
  pre-shared-key address X.X.X.X key crypto-key
crypto isakmp policy 10
 encr 3des
 group 2
 lifetime 28800
 encr aes 256
 hash sha256
 group 5
 lifetime 28800
   keyring PHILIPS
 mode tunnel
 set peer X.X.X.X
 match address 129
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface Ethernet0
 no ip address
 shutdown
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 switchport access vlan 20
 no ip address
 duplex full
 speed 1000
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface GigabitEthernet8
 description --- Telstra Fibre ---
 ip address Z.Z.Z.Z 255.255.255.252
 ip nat outside
 ip inspect TELSTRA out
 ip virtual-reassembly in
 duplex auto
 speed auto
 service-policy output TELSTRA_50mb
interface Vlan1
 description ---  LAN ---
 ip address 192.168.150.1 255.255.255.0
 ip access-group netout in
 ip flow ingress
 ip flow egress
 ip nat inside
interface Vlan20
 no ip address
interface Dialer1
 description --- NBN VDSL PPPoE ---
 ip address negotiated
 ip access-group qldwifippp in
 ip mtu 1492
 ip nat outside
 ip inspect FW out
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 ppp authentication chap callin
 ppp chap hostname care247@provider
 ppp chap password 0 zzzzzzzzzz
ip local pool vpnpool 192.168.29.2 192.168.29.10
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-top-talkers
 top 30
 sort-by bytes
 cache-timeout 30000
ip nat inside source route-map Telstra interface GigabitEthernet8 overload
ip nat inside source route-map internet interface Dialer1 overload
ip nat inside source static udp 192.168.150.4 80 110.145.252.66 80 extendable
ip nat inside source static tcp 192.168.150.248 801 110.145.252.66 801 extendable
ip nat inside source static udp 192.168.150.4 80 202.191.10.22 80 extendable
ip nat inside source static tcp 192.168.150.7 3389 202.191.10.22 6310 extendable
ip nat inside source static tcp 192.168.150.8 3389 202.191.10.22 6320 extendable
ip nat inside source static tcp 192.168.150.6 3389 202.191.10.22 6330 extendable
ip route 0.0.0.0 0.0.0.0 110.145.252.65 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 10
ip route 150.101.15.42 255.255.255.255 110.145.252.65
ip access-list extended TEST
 permit ip any any
ip access-list extended Telstra
 permit icmp any any
 permit icmp any any echo-reply
 permit udp any host Z.Z.Z.Z eq 80
 permit ip host X.X.X.X host Z.Z.Z.Z
 permit esp any any
 permit tcp host 150.101.15.42 any eq telnet
 permit tcp host 150.101.236.166 any eq telnet
 permit udp any any eq isakmp
 permit udp any any eq non500-isakmp
 deny   ip any any log
ip access-list extended netout
 permit ip 192.168.150.0 0.0.0.255 192.168.150.0 0.0.0.250
 permit ip 192.168.150.0 0.0.0.255 192.168.29.0 0.0.0.250
 permit ip 192.168.29.0 0.0.0.255 192.168.150.0 0.0.0.250
 permit tcp host 192.168.150.65 any eq smtp
 permit tcp host 192.168.150.248 any eq smtp
 permit tcp host 192.168.150.3 any eq smtp
 deny   tcp 192.168.150.0 0.0.0.255 any eq smtp log
 permit ip any any
ip access-list extended qldwifippp
 permit icmp any any
 permit tcp any host N.N.N.N eq 6330
 permit tcp any host N.N.N.N eq 6320
 permit tcp any host N.N.N.N eq 6310
 permit udp any host N.N.N.N eq 80
 permit esp any any
 deny   ip any any log
ip sla 1
 icmp-echo X.X.X.Z source-interface GigabitEthernet8
 threshold 2
 frequency 5
ip sla schedule 1 life forever start-time now
route-map internet permit 10
 match ip address 101
route-map Telstra permit 10
 match ip address 103
access-list 1 permit 192.168.16.0 0.0.0.255
access-list 1 permit 192.168.150.0 0.0.0.255
access-list 1 permit 192.168.29.0 0.0.0.255
access-list 101 deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 101 permit ip 192.0.0.0 0.255.255.255 any
access-list 102 deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 102 deny   ip 192.168.0.0 0.0.255.255 host 150.101.15.42
access-list 102 permit ip 192.0.0.0 0.255.255.255 any
access-list 103 deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 103 deny   ip 192.168.150.0 0.0.0.255 host 172.34.10.159
access-list 103 permit ip 192.168.0.0 0.0.255.255 host 150.101.15.42
access-list 103 permit ip 192.168.0.0 0.0.255.255 any
access-list 120 permit ip 192.168.29.0 0.0.0.255 192.168.150.0 0.0.0.255
access-list 120 permit ip 192.168.150.0 0.0.0.255 192.168.29.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line vty 0 4
 access-class 1 in
 exec-timeout 120 0
 password xxxxxxxxxx
 transport input all
scheduler allocate 20000 1000
end
thanks, I'll see what can be added/changed...
I took your advice and added this:
interface Tunnel0
 ip address 10.1.1.1 255.255.255.0
 tunnel source GigabitEthernet8
 tunnel mode ipsec ipv4
 tunnel destination 52.62.169.168
 tunnel protection ipsec profile Philips
Removed the clientmap from Gig8 and I can now see it up with traffic.
Interface: Tunnel0
Session status: UP-ACTIVE
Peer: 52.62.169.168 port 4500
  Session ID: 0
  IKEv1 SA: local 110.145.252.66/4500 remote 52.62.169.168/4500 Active
        Active SAs: 56, origin: crypto map
Interface: Tunnel0
Peer: 52.62.169.168 port 500
  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
247care.qld#ping 172.34.10.159 source vlan 1
Sending 5, 100-byte ICMP Echos to 172.34.10.159, timeout is 2 seconds:
Packet sent with a source address of 192.168.150.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/16/20 ms
Thanks. I think this is the solution. Thanks for your guidance. I’ve been banging my head on this for a week and such a simple solution.
