Cisco 1921 adsl and load balancing
HI,
i am trying to configeure a cisco 1921 router with adsl and load balancing. i am not to sure if the config i have done will work. at the moment the lines are both fault.
here is the config that i have done so far.
AIDC01R#sho run
Building configuration...
Current configuration : 3431 bytes
! Last configuration change at 14:57:05 UTC Tue Oct 1 2013 by mars
version 15.2
service password-encryption
hostname AIDC01R
boot-start-marker
boot-end-marker
enable secret 4 iUu5KFbyns7bMwYiStzvHwru7Xj7ZwnUe3UawdnCQR2
no aaa new-model
ip cef
ip routing
no ip domain lookup
no ipv6 cef
license udi pid CISCO1921/K9 sn FCZ173692E1
username mars password 7 00291214174F0E050770
redundancy
controller VDSL 0/0/0
controller VDSL 0/1/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description Vlan 10 - Management
encapsulation dot1Q 10
ip address 192.168.121.1 255.255.255.192
ip nat inside
interface GigabitEthernet0/0.20
description Vlan 20 - Servers
encapsulation dot1Q 20
ip address 192.168.121.65 255.255.255.192
ip nat inside
interface GigabitEthernet0/0.30
description Vlan 30 - Admin
encapsulation dot1Q 30
ip address 192.168.121.129 255.255.255.192
ip helper-address 192.168.121.66
ip nat inside
interface GigabitEthernet0/0.40
description Vlan 40 - Guests
encapsulation dot1Q 40
ip address 192.168.121.193 255.255.255.192
ip nat inside
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
description connection to telkom
no ip address
no atm ilmi-keepalive
no shut
interface ATM0/0/0.35 point-to-point
description telkom adsl
pvc 8/35
  pppoe-client dial-pool-number 1
interface Ethernet0/0/0
no ip address
shutdown
interface ATM0/1/0
no ip address
no shutdown
interface ATM0/1/0.35 point-to-point
pvc 8/35
interface Ethernet0/1/0
no ip address
shutdown
interface Dialer0
ip address negotiated
no ip redirects
no ip proxy-arp
ip mtu 1492
ip nat outside
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname *****************************
ppp chap password 7 *************************
ppp pap sent-username *********************** password 7 *************************
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
no cdp enable
description To Telkom ADSL 1
no ip redirects
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
interface Dialer1
description To Telkom ADSL 2
no ip redirects
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname vnaidooaidc@telkomsa.net
ppp chap password 7 097C5A011E111A5C5E
ppp pap sent-username vnaidooaidc@telkomsa.net password 7 081158460E0D085947
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard NAT
permit 192.168.121.0 0.0.0.255
ip nat inside source list NAT interface dialer0 overload
ip nat inside source list NAT interface dialer1 overload
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
can any body please help
cadet alain
if you want to do NAT overload over 2 WAN links your config should look like this:
route-map DIAL0
match ip add NAT
match interface dialer0
route-map DIAL1
match ip add NAT
match interface dialer1
no ip nat inside source list NAT interface dialer0 overload
no ip nat inside source list NAT interface dialer1 overload
ip nat inside source route-map DIAL0 interface dialer0
ip nat inside source route-map DIAL1 interface dialer1
Also provide output from following:
-sh ip int br | exc una
-sh ip route static
Alain
