Cisco 1921 can't ping from internal interface
toothlessdr4gon
Hi Everyone,
I'm having trouble configuring a Cisco 1921 router to provide internet access through our Comcast Business modem. From the console I can ping www.google.com, I can ping the google dns 8.8.8.8, and I can ping other devices that are plugged into the comcast modem (which is connected via the GigabitEthernet 0/1), but I can't ping the comcast dns servers 75.75.75.75 or 75.75.76.76
When trying to configure it throught the CPP application, I tried running a "test connection" on the 'outside' interface which is successful, but running a ping test on the 'inside' interface fails on the "Checking exit interface" and suggests: "Selecte 'User-specified' option or add a 'host specific/network specific/default' route through this interface and retest connection".
Any help is Greatly appreciated and I'll be sure and rate any/all helpful posts!
Here's my running config:
Building configuration...
Current configuration : 8664 bytes
! Last configuration change at 19:09:44 UTC Wed Nov 13 2013 by admin
! NVRAM config last updated at 19:00:30 UTC Wed Nov 13 2013 by admin
version 15.1
hostname cisco1921
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name yourdomain.com
ip name-server 50.*.*.126
crypto pki trustpoint TP-self-signed-3493286146
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3493286146
revocation-check none
rsakeypair TP-self-signed-3493286146
crypto pki certificate chain TP-self-signed-3493286146
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33343933 32383631 3436301E 170D3133 31313132 32313538
  35355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 34393332
  38363134 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A035 6535C8CE D3D8AAC8 3EF62D40 A959747B 3EAE4254 B043F333 39DE9A3A
  C8A6CE75 FB637218 E228A2AF B590CC52 D058A449 7AD9CF5F 8B16A7FA EE118335
  5D6DB996 71C5B10C A3D1EDA6 71EB8EBF F35BDA97 E9A1FAC9 52E63898 0BBA1C02
  3AB4EB18 68CDB957 A03B6EE8 9BC0897D 432053B5 9C5DE96F CFA9D634 9AADB3FE
  AA6D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 144CCBCB 206F65C5 C5D03E32 52520352 AEA6CA13 83301D06
  03551D0E 04160414 4CCBCB20 6F65C5C5 D03E3252 520352AE A6CA1383 300D0609
  2A864886 F70D0101 05050003 81810036 A9530BFB 4EB1AAA2 B80CC4D2 4F5201B3
  938F6BC9 46A50B9D 52BF8890 CB35D131 637D16A0 58CDDE40 B2BBB99A 960FCDE0
  209207AF A414CBA8 0E706F9D 0B694AC7 1EC9BF19 D9EE5F96 C1871FCE 2C385389
  538137F8 DEE25686 9D8BA891 7DDC5360 460CCEF9 E5168F2F D67AA44C 4F2ADA6F
  E133AAA6 05DC8C68 FC09B229 E84C51
            quit
license udi pid CISCO1921/K9 sn FTX1637810Q
username admin privilege 15 secret 4 O93TqN1DZfLJEmVUW78Kx961yfx/6d6NqkHjYA8I4iA
username jost privilege 15 secret 4 S3GgPN01m4oSTi7Usr/wj4mf58eOZAUeIOCuyy7rc7c
redundancy
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any CCP_PPTP
match class-map SDM_GRE
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol pptp
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class class-default
  drop
policy-map type inspect ccp-pol-outToIn
class type inspect CCP_PPTP
  pass
class class-default
  drop log
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-zone-To-in-zone source out-zone destination in-zone
service-policy type inspect ccp-pol-outToIn
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.129 255.255.255.0
ip nat inside
ip virtual-reassembly in
zone-member security in-zone
ip tcp adjust-mss 1452
duplex auto
speed auto
interface GigabitEthernet0/1
description $ETH-WAN$$FW_OUTSIDE$
ip address 50.*.*.124 255.255.255.240
ip nat outside
zone-member security out-zone
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 50.193.37.126
ip access-list standard FOR_NAT
permit 10.10.10.0 0.0.0.255
ip access-list extended SDM_GRE
remark CCP_ACL Category=1
permit gre any any
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 50.*.*.112 0.0.0.15 any
control-plane
banner exec ^C
Abzal
Level 7
Level 7
You should NAT rule to translate internal subnet 10.10.10.0/24 to public IP address.
Just add this:
ip nat inside source list FOR_NAT interface g0/1 overload
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Abzal
Level 7
Level 7
Just add this:
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Abzal, YOU ARE MY CISCO HERO!!!
That was exactly what I needed!
I'm still having a strange issue of not being able to ping the comcast dns servers though (75.75.75.75 and 75.75.76.76). But I have internet now which is WAY more than I had yesterday! Now I to sort out port forwarding... Don't suppose you have the easy answer for that too? I think I just need to do this:
ip nat inside source static tcp   extendable
Does that look about right?
Thanks!
yes this is correct syntax for static PAT aka port forwarding.
Alain
Thanks for confirming that Alain, worked like a charm
