Cisco 1921 Configuration for IP private ISP + Public IP Wan + DHCP Private Network
hi,
I have to configure a 1921 Cisco Router , i  search on multiple video how to..no problem
But in my case, the ISP send me that his Wan Network type exemple 192.168.23.82/30 and  IP Public 41.110.187.86/30
i need to configure also this Cisco 1921 in DHCP for the workstation network 192.168.1.0
how the Cisco with two Ethernet interface can do that ..?
thanks by advance
Djamel
6 Replies 6
Hello
The basic setup internet connectivity is fairly straight forward, Whats not included here is hardening of the router for security purposes which is a bit more in depth. but it could be possible you may have an ISP modem peforming FW activites infront of your router also?
Note: I have used a public dns server for name resolution in dhcp, Obviously change this to your ISP's if applicable, and the public addressing I have given the router the higher of the two addresses, but this could be the other way round.
int fa0/0
description WAN Interface
ip address  192.168.23.84 255.255.255.252
int fa0/1
description LAN
ip dhcp pool LAN-Addressing
network 192.168.1.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.1.1
lease 0 12
ip dhcp excluded-address 192.168.1.1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0  192.168.23.83 name ISP-NEXTHOP
res
Paul
Kind Regards
Paul
thanks for response...but the ISP send two IP ...
the WAN Network IP 192.168.23.82/30
and the Public Netword IP 41.110.187.86/30
So My network will be
   ISP  Gateway                                 My Router 1921                                        Private Local LAN
 192.168.23.83                   WAN0/1:192.168.23.84 / Public:41.110.187.87           192.168.1.x
                                                            LAN0/0:192.168.1.1
thanks
Hello
Okay so it seems that your isp is most probably natting for you so I have revised the config
res
Paul
Kind Regards
Paul
Hi.. don't see your revised config...
Can you send it
Hello
i edited my first post please review it
res
paul
Kind Regards
Paul
meharihadis
Dears
How are u?
Can you help me for the following issue
Let say my customer is public IP custo mer
I.e my ISP gives two WAN IP address
10.187.63.26/30
167.178.64.56/29
And also lan IP 192.168.0.1/24
So how I can configure these IP addresses .pls help me As much as possible.
