Cisco 1921 Keep lost internert connection
nineapple
My network was upgraded from 100Mbps to 1000Mbps recently, thus I changed from 1841 to 1921
But seems some problems on 1921, it keeps disconnecting from internet.
For short, it can run for 10-30mins then lost internet connection.
I tried to ping 8.8.8.8 on 1921 but failed when i found my PC internet lost.
There are two ways to get the internet back
1: reload command
2: go to interface g0/0, key in ip address dhcp
G0/0 ---connect to a Fiber modem, use DHCP
G0/1 ---connect to a cisco 2960CG-8TC
no idea how to trouble shooting .
below is the show run output
Building configuration...
Current configuration : 2180 bytes
! Last configuration change at 09:50:48 UTC Wed Mar 7 2018
version 15.1
hostname HOMERT01
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXX
enable password XXXXXXX
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.1.3
ip dhcp pool HOME
 network 192.168.1.0 255.255.255.0
 dns-server 192.168.1.1
 default-router 192.168.1.1
no ip domain lookup
license udi pid CISCO1921/K9 sn XXXXXXXX
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip dhcp client update dns
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex full
 speed 1000
 no cdp enable
interface GigabitEthernet0/1
 ip nat inside
 duplex auto
 speed auto
 no mop enabled
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 11 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX 254
access-list 11 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password XXXXXX
 login
 transport input all
scheduler allocate 20000 1000
end
Julio E. Moisa
Have you tried configuring a static IP of the range provided by the ISP? And without ip dhcp client update dns.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
seems impossible,
The public ip which assigned by ISP jumps at every reboot
some times 58.xxx, or 202.xxxx
But the old 1841 works quite good.
