Cisco Router 3945, Write Memory command not working
Narbondel
Goof Afternoon All,
I am using a Cisco 3945 Router, and when I 'Write Memory', the running config does not save to the flash.
I just updated to IOS version (3900-UNIVERSALK9-M), Version 15.4(3)M8
Configuration Register is set to 0x2102
the command 'copy run start' also doesn't work, however
the command 'copy run flash:' does work, This is slightly inconvenient for when other people make changes and think they saved it.
How would I go about fixing this?
Router#sho version
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.4(3)M8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 31-Jul-17 05:54 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 22 minutes
System returned to ROM by reload at 23:39:17 UTC Mon Mar 5 2018
System image file is "flash0:c3900-universalk9-mz.SPA.154-3.M8.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 2021376K/75776K bytes of memory.
Processor board ID FTX1711ALBJ
6 Gigabit Ethernet interfaces
8 Serial(sync/async) interfaces
3 terminal lines
1 Channelized (E1 or T1)/PRI port
2 Virtual Private Network (VPN) Modules
1 cisco ISM Crypto Engine(s)
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
500472K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        C3900-SPE150/K9       FOC17027ZGC
Technology Package License Information for Module:'c3900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      securityk9           Permanent      securityk9
uc            uck9                 Permanent      uck9
data          None                 None           None
NtwkEss       None                 None           None
CollabPro     None                 None           None
Deepak Kumar
I am not much familiar with this router but this command should be work.
Are you trying in Global configuration?
Are you trying "copy running-config startup-config"?
I am not sure where are you wrong? but please try those commands in "Privileged EXEC" mode only.
If you trying in any Configuration mode (as Global or subinterface etc) then must use "do" keyboard before the command.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Leo Laohoo
Is there an error message that appears when this happens?  Or with you issue to command "wr mem" the process doesn't end?
