Cisco 1921 ROUTE error
sukant_kumar
Hiii
 I have getting a problem in cisco 1921 router
Error message:-
DDR Memory Test failed ! stop.
I need solution for resolving error
Screen Shoot attached
Philip D'Ath
If you have a maintenance contract contact TAC to get the device swapped out.
Otherwise you will need to get the RAM replaced in the router, or replace the router.  I don't know the exact specs - it is some kind of non-ECC UDIMM.
Take the UDIMM out of the router and the specs will probably be on it somewhere.
