cisco 1921 router performance
jackson.ku
Level 3
Level 3
What is the Cisco 1921 router performance if connected with 2 Giga Ethernet port? What is the performance if enable GRE tunnel?
Best Regards,
Jackson
Sandeep Choudhary
we are running in the same philosophy and its runnig perfectly with good performance.
There are some problem in router 2911 and uper version.(Like due to WCCP AUTOMATIC TUNNEL CREATIONS::9
please rate if it helps.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
The 1921 is documented as being able to push up to 2,770 Kbps yet it's also only recommend for up to 15 Mbps WAN circuits.
