Cisco 1921 Router: setup default gateway on WAN site with fix IP-adress
cisco1211
I need to setup a Cisco 1921 Router.  On the WAN site i have to setup a default gateway.  How can I do this?
Thanks for helping me.
bolick
The easiest way, assuming you want this router to actually route, is to use a static default route. ip route 0.0.0.0 0.0.0.0 <gw ip address> will do the job.
bolick
