Device Serial Number Validation
tsavage
Is there a Cisco feature on CCO that will validate a Cisco serial number? If such a feature does exist does it require special access privileges?
mmorris11
Level 4
Level 4
You can use the Service Contract Center:
http://www.cisco.com/public/scc/
login and use the Quick Search for serial #.
HTH pls rate!
mmorris11
Level 4
Level 4
HTH pls rate!
stevekecskes
This article should be removed since - as of Oct, 2017, Quick Search is not an available option at the referenced link.
