cisco 1921's GE ports are down.
wardhanwork
Hello, I recently started preparing for CCNA and bought a 1921 router for home lab. I was configuring ip address and noticed the status of the port changed from administratively down to down. I looked up and understood that this may be a hardware issue. Both GE ports are down. What can I do now??
balaji.bandi
is anything connected to port ? if not that will show as down.
connect any device PC / switch to that port that will come up
as per informaiton this what i can think of - for btter understand
post below output
show interface gig x/x
show run interface gig x/x
(x/x is the interface you claiming as down)
BB
it used to be that you could bring the interface up, even when nothing is connected to the interface, by issuing the 'no keepalive' command under the interface. Not sure if that is still possible...
