Cisco 1921 sample working config for VDSL with a VA-DSL-A card?
WStoffel1
The problem i'm running into is all the sample configs for this card i'm finding are for much older code, i need it for a 1921 with version 15.2(3)T.
Any help is very much appreciated.
I believe you have an EHWIC-VA-DSL-A card installed on the C1921 device.
The sample configuration for the same would be as follows,
1. Configure the Controller,
controller VDSL 0/0/0
operating mode vdsl2
firmware filename flash:vdsl.bin-A2pv6C035j1
2. Configure the Ethernet interface & its sub-interface as follows,
interface Ethernet0/0/0
no ip address
l
interface Ethernet0/0/0.2
encapsulation dot1Q 2  ---------> Need to confirm the VLAN TAG ID from the ISP
pppoe enable group global
pppoe-client dial-pool-number 1
3. Configure the Dialer interface and as per you requirements, you can configure the Authentication, IP addressing etc.
interface Dialer1
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname _______
ppp chap password ________
ppp pap sent-username ______ password _______
Let me know if this was what you were looking for and if it works for you.
Mithun
Hi Mithun,
Thank You for your example above, as I am currently trying to set this up as well.  One question though....does the ehwic-VA-dsl-A module come with software by default, or do you need the "firmware filename flash:vdsl.bin-A2pv6C035j1" command and the firmware for VDSL on the router?  Thanks.
Eddie
