Cisco 1921 System returned to ROM by processor memory parity error
d.dragoev
I recently bought Cisco 1921 from Ebay. I configured it and it worked for a while, but it started restarting on its own. I updated the firmware, but it continues again ...
00:00:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down
Error: primary instr cache, fields: ,
virtual addr 0x8169A30C, physical addr(21:3) 0x0040C8, vAddr(14:12) 0x1000
virtual address corresponds to main:text, cache word 1
Cache Data not Available for CPU D07
Address: 0x8169A300 not in TLB
09:11:15 UTC Tue May 23 2017: Interrupt exception, CPU signal 20, PC = 0x81014A50
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
rlh uptime is 2 hours, 6 minutes
System returned to ROM by processor memory parity error at PC 0x22B9421C, address 0x0 at 10:17:53 UTC Fri Feb 12 2021
System image file is "flash:c1900-universalk9-mz.SPA.158-3.M5.bin"
Cisco CISCO1921/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Leo Laohoo
@d.dragoev wrote:
   Possible software fault.
   Please collect crashinfo, "show tech" and contact Cisco Technical Support.
Try upgrading the firmware of the router.
if upgrading the firmware as suggested by Leo doesn't help, you also might want to try and open the chassis, and reseat the DRAM.
